Sirin/Minitaur octave up/down
hieronymous
Post by hieronymous » Tue May 31, 2022 12:53 pm
I love playing my Sirin with either Roland PK-5A or McMillen 12-Step bass pedals. However, in both cases, switching octaves requires two button pushes. On the Roland, it doesn't happen instantly, I find there is a noticeable delay. On the 12-Step, the Select button is hard to push, despite adjusting the pedal sensitivity.
OK - enough complaining - is there some MIDI footswitch that can be used/set to switch octaves with one click?
ummagumma
Re: Sirin/Minitaur octave up/down
Post by ummagumma » Thu Jun 02, 2022 8:34 pm
That's a good idea: a device that can run customized MIDI cc commands, assigned to a footswitch?
There must be something like that out there. Didn't Moog make a multifunction MIDI pedal, a few years ago?
till
Post by till » Fri Jun 03, 2022 3:57 am
ummagumma wrote: Thu Jun 02, 2022 8:34 pm ...
The Moog MP-201 was hard to program, as there was never an editor.
Sequence:
stiiiiiiive
Post by stiiiiiiive » Fri Jun 03, 2022 5:22 am
Plus it is quite stellar priced on the used market now.
You may want to check out the MidiSolutions products,: they propose a lot of programmable boxes and their sw editor.
For example, the Dual Footswitch Controller could help you.
I know this brand since a long time but have never their products.
One step further is to get a small cpu board, e.g. Arduino, and develop your own firmware. I've thought about this to make my Little Phatty duophonic... maybe some day :)
Oh and if you happen to have a Clavia G2, it will do the job too but is quite cumbersome for this use :D
hieronymous
Post by hieronymous » Sat Jun 04, 2022 3:20 pm
Thank you for the suggestions!
I think the Morningstar MC-3 would work. Not seeing them in-stock - hope they still make them! I don't need to do a lot of things - just shift octaves and maybe select presets.
stiiiiiiive
Post by stiiiiiiive » Mon Jun 06, 2022 5:44 pm
I did not know about those MorningStar products, thanks for sharing.
As far as just changing presets, the Tech 21 MidiMouse could do the job.
ummagumma
Post by ummagumma » Tue Jun 07, 2022 9:28 pm
Yes, those Morningstar controllers look pretty slick!
Thx for the link & info
