drone on subsequent 25
Can anyone help me fix the parameters to keep not continues to create stand alone drone
- stiiiiiiive
Re: drone on subsequent 25
You can find the DRONE MODE combo in the cheat sheet, available on MoogMusic website.
thanks for reply , I can't find any chat sheet apart from for sirin which I already have .
- stiiiiiiive
This is the one
EDIT: oups, sorry... had Sirin in mind!
For Sub Phatty or Subsequent 25, I can't seem to find such a mode. I guess you have to:
1- make sure the filter is open to make sure you are doing next steps correctly,
2- set all the oscillators volumes to zero
3- set the amplitude envelope parameters "full open", i.e. minimum attack and decay, maximum sustain and release
4- keep the amplitude envelope open as long as you want the signal to be processed. This can be achieved by maintaining a key open or using the GATE CV input with a dummy plug or a sustain pedal. Pay attention to the fact that if the filter KEY AMT parameter is not 0, the filter cut off freequency will follow the key you are pressing.
5- adjust the EXTERNAL INPUT LEVEL (as per manual: shift mode + Noise volume knob)
Hope this helps... better
Hey thatnks for taking the time to help . I did actually remebmeber about using the dummy jack . But just seems absurd theres no latch mode to keep notes running ! also in duo mode it will only drone one note on keyboard with the dummy jack - only way seems to be to keep 2 notes on kb is to hold - its quite annoying !
- stiiiiiiive
First off, I'm sorry as I mentioned many points thinking about processing external signal by the Sub 25. Sorry I payed more attention
My trick when it comes to droning my Little Phatty is a simple one. I've used it live several times, really
- RobustAmerican
You could always try the old piece of tape method in a pinch. Use a piece of mixing console tape to hold the key down.
