Hi all - I'm now the the forum. I picked up my new Moog One last week and it is amazing. I've managed to crash / hang it three times since I've got it. I think usually something to do with the arp. Wondering what others experience is and if it's typical.
It is running the latest firmware.
Thanks in advance.
Moog One crash / hang
Re: Moog One crash / hang
If your M1 is connected via MIDI, you may have created a MIDI loop, which would cause a hang.
Thanks for the reply. I have USB connected to it from my Mac (for Logic). No midi.
That will be the issue. Although not sure why you say no midi?Thanks for the reply. I have USB connected to it from my Mac (for Logic). No midi.
Thanks for the reply. I was thinking no midi as in no midi cables (in, out, through) that would create a midi loop as was suggested.
So sorry, why would the USB connected be the issue?
USB is just a modern replacement for traditional MIDI cables. You can create a MIDI loop regardless of the type of connection. Check your setting on M1 and in Logic. Especially the MIDI clock routing. Please note that M1 doesn't have yet a proper "Local Off" mode for interfacing with a DAW.
Ok cool - thanks for the tip. I'll check that out.
