loud Popping from inside of the Moog one - anyone else?
Polyphonic Analog Synthesizer
SanhajiMusic
Post by SanhajiMusic » Fri Nov 08, 2019 12:29 pm
I have a loud Popping from inside of the Moog and I know this is because of thermal expansion.
It starts when I turn it on and it sounds long after I turn it off again
This makes me crazy.
I already talk with somebody from Moog about this and he told me this is a normal Problem but i cant believe it.
anyone else have this?
till
Re: loud Popping from inside of the Moog one - anyone else?
Post by till » Fri Nov 08, 2019 3:12 pm
Here too, but only sometimes.
I think these are the inlay panels left and right of the display sections. These panels sit in a frame that is as long as the whole panel. And the heat from below expands the frame and the panels. But most likely not at the very same amount.
Sequence:
TabbyCatte
Post by TabbyCatte » Fri Nov 08, 2019 3:48 pm
Yup, it's happening right now for me.
Remember that there are quite literally 16 analog synthesizers inside - for example the 4 LFOs are not per synth, or per patch - they are per voice. I.e. there are 64 completely independent LFO circuits (4 LFOs x 16 voices), which are all spinning with their own phase. That's just the LFOs.
It's no coincidence that the sides and back of the unit are essentially one massive heat dissipator.
SanhajiMusic
Post by SanhajiMusic » Fri Nov 08, 2019 6:00 pm
Thanks for your answers..
donwp
Post by donwp » Fri Nov 08, 2019 11:06 pm
Loud expansion and contraction noises have always been part of my unit's behavior. My Moog One 16 is drawing 127W from the wall outlet, so there's a lot of heat generated internally, which of course is why the fans are required.
rudylost
Post by rudylost » Sat Nov 09, 2019 6:35 am
Same here
one or more little pops after power down
never worried about it , same as a car engine cooling down :)
ummagumma
Post by ummagumma » Sun Nov 17, 2019 2:52 am
possible to add a tray to the ONE, so you could warm up a slice of pizza inside while you're playing?
or better yet: popcorn!
SanhajiMusic
Post by SanhajiMusic » Thu Nov 21, 2019 11:29 am
I have now found out that not everyone has this expansion noise. So a production error?
I send 2 emails to the Moog support, no answer.
Iaamusic
Post by Iaamusic » Fri Nov 22, 2019 2:35 am
Who hasn’t got it?
It’s mentioned in most detailed reviews and on mine when it’s been operating a while and it’s all warmed up stops.
Midiguy4u
Post by Midiguy4u » Sun Dec 29, 2019 11:16 am
Yes, clicking/popping noise here too. I think it has something to do with the unit warming-up.
Moog System 55 with controller.Synthesizers Studio System 110 with controller, Voyager XL, (9) Moogerfoogers,(3) Mothers, (2)500-series Ladder filters, (2) 500-series analog delays. [img]fullmodular.jpg[/img]
aaronramsdale
Post by aaronramsdale » Thu Sep 22, 2022 3:31 am
I am having the same problem as you. Do you find any solution for this?
Iaamusic
Post by Iaamusic » Sun Sep 25, 2022 4:37 pm
It’s normal, don’t worry about it.
