Model D reissue, Keyboard tuning error NOT working?
Dr.Sax
Re: Model D reissue, Keyboard tuning error NOT working?
Post by Dr.Sax » Sat Sep 09, 2017 9:48 am
I def. needed to update my firmware to get everything working as described.
Oldworldman
Post by Oldworldman » Wed Oct 25, 2017 3:40 pm
I have contacted Adam Pryor in tech support about this because mine straight out of the box new had this issue.
We verified that Firmware version 1.8 was in the unit successfully and even reloaded it successfully without any change to the issue.
My particular symptom was I had a sub oscillator clicking noise after I initiated the function and pressed a key, not no sound completely like some of you have stated. I then had no Oscillator control after that either.
Here is a video clip I sent to tech support demonstrating the problem I had with my unit: https://youtu.be/qr6H9NN_DJY
They had a unit on the bench that did exactly the same thing. As of now, all we can do as Minimoog Reissue Owner's, is wait for the next version of Firmware that will fix this problem and upload it when it is available if you want this turn on function to work.
If you have a minimoog reissue to where this function works, then you are lucky. I will keep all of you posted via this forum if the next firmware version works as I will be receiving Beta test versions to see if it will work in my unit.
Analogmofo
Post by Analogmofo » Tue Sep 25, 2018 2:27 am
Any word on a fix for this, I have the recent Walnut version and have the same issue
khusboo
Post by khusboo » Mon Feb 25, 2019 2:02 am
There is note need: this lets you pick which note pitch is heard when all the more then one key is pushed down. Unique Minimoog utilized low note need: dependably the most reduced played key was utilized for the pitch data.
Trigger modes: There are Single trigger and various trigger. The principal will possibly restart the envelope when every held note is discharged. This is the way the first Minimoog used to trigger the envelopes. This mode is expected to play legato (changing the note pitch without another note enunciation).
The various trigger will dependably begin another note when another key is squeezed. You can't play legato in this mode.
Signman
Post by Signman » Thu Sep 19, 2019 6:31 am
I'm disappointed to learn this is a common problem.
Mine also is not able to give me the 'Keyboard Error' option.
Something I feel is a must have .
It seems early production they had it and later it was missed off ..I'm unable to check which firmware I have
but my Minimoog Model D is showing passed QC July 2017
Presume 1.8
Actually considering selling mine as the factory don't seem interested :x
Anyone able to update and get it working ?
till
Post by till » Fri Sep 20, 2019 5:07 pm
Signman wrote: Thu Sep 19, 2019 6:31 am...
Presume 1.8
You can check the firmware version via SysEx
From the manual:
Code: Select all
TRANSMIT FIRMWARE VERSION
   F0 04 15 7F 15 00 00 00 F7
   (Hardware will output the following:
   F07E 7F 06 02 04 00 15 00 01 00 00 [v_min][v_maj] F7
   Where v_maj is major version number and v_min is minor version number)
So send this SysEx command to the Minimoog while you record/monitor its output:
And your Minimoog will respond with
F0 7E 7F 06 02 04 00 15 00 01 00 00 [v_min][v_maj] F7
If its actually
F0 7E 7F 06 02 04 00 15 00 01 00 00 08 01 F7
you are on version 1.8
I am using a MacOS, therefor I use SysEx Librarian to send SysEx files.
And MIDI Monitor to record the ingoing SysEx string.
Both software apps are free.
I put the needed tiny SysEx file here (in case you can't create them yourself)
Sequence:
ummagumma
Post by ummagumma » Fri Sep 20, 2019 9:15 pm
has anyone tried installing an older firmware, prior to 1.8, to see if that restores the function?
Signman
Post by Signman » Sun Sep 22, 2019 10:33 am
Last reply from the factory .
See below.
Jared (Moog Music)
Sep 20, 09:09 -05
Hey Paul,
I'm sorry I don't have better info for you. The problem is within the firmware and is a known issue that affected Model D reissues across the entire serial range. Tuning-error mode is stored digitally on the key scan card. However, replacing the key scan card has proven to be unsuccessful. Oddly, there are some units that are able to power up in tuning-error mode. There's a small chance that a firmware reload will resolve the issue for you but I'm doubtful. Let me know if there are any other questions that you have.
Best,
Jared
Attachment(s)
Model_D_firmware_v1_8_0.zip
Signman
Post by Signman » Sun Sep 22, 2019 10:42 am
Thank You Till.
I will look into this, will need a cable.
I don't use software or midi.
I'm wondering if the previous firmware may give me the option for Keyboard Error.
What did the latest update give you over the previous ?
ummagumma
Post by ummagumma » Mon Sep 23, 2019 1:45 pm
yes, that is the first thing I would try
does Moog have a changelog documenting the updates, between firmware versions?
that is normal in most industries
till
Post by till » Mon Sep 23, 2019 2:57 pm
From the 1.8 change log:
New in 1.8.0
• Prior to 1.8, when using your Minimoog Model-D as a midi controller, pitch wheel data was offset from the original note value. 1.8 fixes this issue.
ummagumma wrote: Mon Sep 23, 2019 1:45 pm...
Do you think music industry is "normal"?
Many synth manufacture give no, incomplete or even wrong change logs with their updates. Luckily, there was a change log for the 1.8 Minimoog Reissue firmware. But I got no older version and their change logs here.
Sequence:
ummagumma
Post by ummagumma » Tue Sep 24, 2019 12:11 am
hahaha well, I usually ( hope to ) find a document listing changes, in software & firmware updates
But I wasn't working in the music industry
thx for posting that info
Signman
Post by Signman » Tue Sep 24, 2019 4:31 am
I had another reply from Moog.
They basically told me I should be grateful I have no hard wear issues !
They are aware of the Keyboard Error issue but being a small company and currently busy on new projects have no time to deal with the Keyboard Error problem on the Re Issue Model D.
Taylor (Moog Music)
Sep 23, 08:08 -05
Hi Paul,
I understand your concerns, but we are a small company and do not have engineering resources to devote to the Model D firmware at this time. We will in all likelihood release a firmware update to the Model D, but our firmware teams have their hands full with instruments currently in production.
The Model D Reissue functions very well as just that: a reissue of the classic Minimoog Model D, and I am not aware of any returns for this issue. I hear your frustration, but hope you can at least take some solace in the fact that you are not experiencing a hardware failure in your instrument.
Please let me know if I can be of any further assistance.
till
Post by till » Tue Sep 24, 2019 1:10 pm
So this answer from Moog is about the same the Taurus 3 users received when asking for a bug free firmware. And guess what: it was due to the Minitaur needeing full attention. but right after this, we would get the update. And nothing happened. For several years! Still waiting.
Sequence:
ummagumma
Post by ummagumma » Tue Sep 24, 2019 3:41 pm
ouch!
so nobody has a link to the older firmware versions?
is it possible to export a firmware file, via sysex?
