Question about heat resistance
Rabalder
Post by Rabalder » Sat Jul 28, 2018 12:08 pm
I have a moogerfooger (mf101) standing on top of an RME audio interface which gets REALLY hot.. Is this a bad idea, or is the mf-electronics robust enough? All my gear is packed inside a live-performance-case, so I need all the space I can get.
I might replace the metal plate underneath the moogerfooger with a a plastic plate that isolates heat better. But Im not sure if its necessary.
Anyone??
MC
Re: Question about heat resistance
Post by MC » Sun Jul 29, 2018 11:49 am
Excess heat is not good for any electronics.
Plastic will be worse. It will melt.
The best approach is either find a way to draw the heat away or replace the audio interface with one that isn't as hot. Frankly that RME is on borrowed time.
Acid Mitch
Post by Acid Mitch » Mon Jul 30, 2018 12:53 pm
The RME is more in danger than the pedal on top of it.
Can you take it out of the case when in use ?
Rabalder
Post by Rabalder » Tue Jul 31, 2018 7:17 am
Thanks for your replies.
Yeah, I figured the RME would be the loser in this battle. After some clever reorganizing I made room for it to breath.
I had to evolve my Tetris-way-of-thinking to include three dimensions. Been cutting foam like crazy. Good stuff :wink:
