DFAM Sync issues
jamesfarrell
DFAM Sync issues
Post by jamesfarrell » Sat Feb 17, 2018 1:36 am
So I am trying to sync DFAM from Elektron A4 Midi OUT. I have the cable that was suggested to me from another forum. And plugged in (red > Run/Stop) (black > Adv/Clock) and it’s coming from the A4 Midi out port. There’s 3 options for the port. DIN24 DIN48 and Midi. DIN24 and DIN48 just cause the DFAM to sequence at a million miles per hour. Not sure what is up with that and no sound. When I unplug the cables and hit Run, it plays and I can hear it. So I’m getting audio. It’s just trying to figure how to sync it.
jamesfarrell
Re: DFAM Sync issues
Post by jamesfarrell » Sat Feb 17, 2018 11:06 pm
Anybody?
mmarsh100
Post by mmarsh100 » Mon Feb 19, 2018 3:13 pm
DFAM does not have MIDI support of any kind. You sync with CV.
jamesfarrell
Post by jamesfarrell » Tue Feb 20, 2018 7:39 pm
Syncing it with CV now from my A4. Thing stays in sync for about 2 minutes and then goes out. Would be so nice if this thing just had MIDI, like most devices nowadays.
mmarsh100
Post by mmarsh100 » Wed Feb 21, 2018 3:25 pm
Agreed.
Acid Mitch
Post by Acid Mitch » Sun Apr 08, 2018 10:46 am
jamesfarrell wrote:There’s 3 options for the port. DIN24 DIN48 and Midi. DIN24 and DIN48 just cause the DFAM to sequence at a million miles per hour.]
You want to give it less Pulses Per Quarter note to get it running slower.
jamesfarrell
Post by jamesfarrell » Sun Apr 08, 2018 11:31 am
I got it setup with my TR-8S with the trig out and it works great.
zamakli
Post by zamakli » Sun May 20, 2018 10:13 pm
This may be stupid question but can you not trigger via midi cable to your soundcard and daw? Not a juno owner but would like to know Edit: the 60 has no midi but can it be used to sync to drum rack or battery or only other external instruments ?
