thealien666 wrote:Very latest purchase:
Nice! That's what I would probably get is the OB-6 Module. I have enough keyboards/synths to fulfill being able to drive it.
That's quite a haul, John - I'm envious! Congrats!JohnLRice wrote:I took delivery of a nice batch of gently used Moogish clones last night! Mostly Mos-Lab plus a STG Mixer and a Moon mult.
Thanks Greg! I've gone way over the top with purchases this year . . .and may suffer for it in the future, but I heard you are supposed to suffer for your 'art' so, I fuess I'm on the right path?GregAE wrote:That's quite a haul, John - I'm envious! Congrats!JohnLRice wrote:I took delivery of a nice batch of gently used Moogish clones last night! Mostly Mos-Lab plus a STG Mixer and a Moon mult.
I only have a single new Corsynth module to add to my system:
I suspect you're going to need another case...JohnLRice wrote:I've gone way over the top with purchases this year . . .and may suffer for it in the future, but I heard you are supposed to suffer for your 'art' so, I guess I'm on the right path?
Yes . . .even though i swore I was done adding cases! I'm actually going to attempt using a DotCom 22 space case and I have plans to modify it a bit. I hope it works!GregAE wrote:I suspect you're going to need another case...JohnLRice wrote:I've gone way over the top with purchases this year . . .and may suffer for it in the future, but I heard you are supposed to suffer for your 'art' so, I guess I'm on the right path?
Thanks Eric. I'm planning on trying to cram WAY more into a the DotCom 22 than is sensible . . . .I hope it works!EricK wrote:John,
They will fit in a dotcom 22, but not with a power supply in there and I was thinking due to the width of the cabinet if you put separated your bus boards enough you won't have any problems with the ribbons.
