http://www.matrixsynth.com/2017/03/behr ... del-d.htmlDepending on the feedback we will then decide if we move further and build a first prototype.
Our targeted retail price is around US$ 400.
Analog Synthesizer with 3 VCOs, 24 dB Ladder Filter, LFO, 16-Voice Poly Chain and Eurorack Format
1. Analog synthesizer with triple VCO design
2. Reproduction of original “D Type” with matched transistors and JFETs
3. 0.1% Thin Film resistors and Polyphenyline Sulphide capacitors for frequency stability
4. Analog signal path based on authentic VCO, VCF and VCA designs
5. 5 variable oscillator shapes with pulse width variation
6. Classic 24 dB ladder filter with resonance
7. Fully analog triangle/square wave LFO
8. Switchable low/high pass filter mode
9. 16-voice Midi Poly Chain allows combining multiple synthesizers for up to 16-voice polyphony
10. Overdrive circuit
11. Noise generator
12. Complete Eurorack solution – main module can be transferred to a standard Eurorack case
13. 46 controls for real-time access of all important parameters
14. External audio input for processing external sound sources
15. Low and high level outputs
16. Comprehensive MIDI implementation with MIDI channel and Voice Priority selection
17. 3-Year Warranty Program
Uli
http://www.matrixsynth.com/2017/03/new- ... nders.html
Apparently this particular discussion online started here;
https://www.gearslutz.com/board/electro ... -idea.html
Let the consternation commence!
