Guys,
Can you trigger/sync the Sub 37 sequencer with a Mother 32 sequencer?
Thanks...
Mother 32 Sequencer / Sub 37 Sequencer Question
Moog Mother 32 System | MF104m | MF105m | MF107 | MF108m | CP251 | Moog Etherwave Theremin | Moog Amplifier
Re: Mother 32 Sequencer / Sub 37 Sequencer Question
Hello Pastoral,
This can only be done via CV as the CV inputs on the Sub 37 are arbitrary and can be changed to clock the internal arp rate, turn the arp on, etc. This can be done in the Global menu under CV Mapping.
I found it hugely complicated and I couldn't get it to work so I gave up on it.
I'm used to setting up sync between all kinds of sequencers but the M32 and the Sub 37 defeat me.
Thanks guys. So it sounds like, yes they can, but it's not very intuitive and straightforward?
I had to build some cables for the patch cords, otherwise it does seem pretty straightforward and fun!Pastoral wrote:Thanks guys. So it sounds like, yes they can, but it's not very intuitive and straightforward?
http://audiotecna.info
I'm going to have another go at it and will report back if I succeed.Pastoral wrote:Thanks guys. So it sounds like, yes they can, but it's not very intuitive and straightforward?
Reporting back - I still can't make the M32 and Sub-37 sequencers work properly together and I don't really have time to figure it out.
If someone does work it out, it would be great of you posted up a guide for simpletons like me.
