MF Delay issue or normal behavior?
Hi, recently I bought the MF delay pedal and I think it is superb quality in sound and build, nevertheless i got a question about the mix parameter, because as I understand when the mix is at 12 o clock o 50%, the "original" sound should be the same volume of the delayed sound right?, well i had noticed that when the mix parameter is in 50% the delayed sound is a little quiet in relation to the "original" sound, so my question is: this is normal? or is something about my pedal, thanks a lot.
Re: MF Delay issue or normal behavior?
I guess you bought minifooger, but this thred is about moogerfoogers.moogforum2 wrote:so my question is: this is normal? or is something about my pedal, thanks a lot.
So, nevermind. I'm sure that your minifooger is ok, because you describe normal work of BBD chip.
Voyager PE, VX-351, 2xCP-251, LittlePhatty SE II, MF-101, MF-102, MF-103, MF-104M, MF-105M, MF-107, MF-108M
