Hi guys
Wondering about the Panel Mode on the Sub 37. Ive noticed that the panel mode doesnt save all changes that I make on the front after powering up and going back into panel mode? This is especially true for the mod bus, pitch bend values and arp settings. Am I missing something?
On the Voyager after turning it back on, the sound/setting you had before is EXACTLY how it was when you turn it off. I am guessing the Panel Mode is supposed to be like that?
Moog Sub 37 Panel Mode
'i used to be a plastic cup..'
-remarkable-
-remarkable-
- stiiiiiiive
Re: Moog Sub 37 Panel Mode
Panel mode is expected to reflect exactly what the panel looks like, i.e. every knob setting. If you move the knobs between the moment you get in Panel Mode and the moment you... get back to it, it's normal the sound is different.
Hey stiiiiiiive
That of course makes sense but its not whats happening.
Im in Panel mode and make my changes, set the modulation values in controllers for MOD1/MOD2, set the Pitch bend values (-12 down, +5 up), so far so good and everything is working ok. Now im done with playing, switch off the synth and go do something else. Now when i turn it back on (without moving any knobs whilst it was off) it defaults to Preset Mode. I switch it back to Panel mode and my previous values are not stored anymore, namely the pitch bend value and the mod section controls..
-remarkable-
-remarkable-
- stiiiiiiive
I understand better: these are not proper panel parameters but rather soft parameters, right?
I guess the panel mode takes the values the former preset has, or maybe there is some sort of default panel parameter set.
Actually I don't have any Sub37, I'm just trying here
Anybody?
Anybody?
Looks like panel mode sets the mod menu parameters to defaults, as for an init patch.
The Sub 37 manual on page 14 says:
This is with FW 1.2.0.
Went to panel mode.
Set Mod2 triangle wave to mod the filter.
Set the Mod2 depth controls - mod wheel, aftertouch, velocity.
Set LFO2 keytrack to 100%.
Got into the Preset Edit menu, and set pitch-bend up/down to "way big"™.
Exited Preset Edit menu.
Verified everything was there in panel mode.
Switched to preset mode, selected several presets.
Went back to panel mode, everything was still set as before.
Back to preset mode.
Powered off, waited a bit, powered on.
Back in panel mode, everything was still set, even pitch-bend.
Also powered-off when in Panel mode, and it was still OK when I came back.
What firmware is your Sub37 running?
I started writing a note saying that maybe you found a bug, because in my attempts to recreate the problem, I also thought that the pitch-bend was "lost" in a power down. In duplicating my steps, I find that it works as advertised. Hmmm.In PANEL mode, the sound you hear reflects the current position of the front-panel knobs and buttons. Parameters in this mode (other than the knobs) are saved in a special buffer, so you can pre-set the panel to retain any non-knob settings you choose.
Went to panel mode.
MBP 2012 | OS X 10.11.6 | Sub 37 #6768
Thanks mikeh11
Ill try this exact sequence when I am next with my Sub 37. I am running the 1.2.0 FW BTW.
Anyone else care to give the below a try to ascertain if it works in the meantime?
@mikeh11 try doing an innit patch on the panel mode and change the pitch wheel bend ammounts and control ammounts and switch off the synth without going into preset mode and see if that works
mikeh11 wrote:The Sub 37 manual on page 14 says:I started writing a note saying that maybe you found a bug, because in my attempts to recreate the problem, I also thought that the pitch-bend was "lost" in a power down. In duplicating my steps, I find that it works as advertised. Hmmm.In PANEL mode, the sound you hear reflects the current position of the front-panel knobs and buttons. Parameters in this mode (other than the knobs) are saved in a special buffer, so you can pre-set the panel to retain any non-knob settings you choose.
Went to panel mode.
-remarkable-
-remarkable-
I can confirm mikeh11's findings!
Also, If you hold the panel button down while in panel mode, the MOD menus parameters gets initialized (I don't think it touches the PRESET menu parameters, since PANEL and PRESET are mutually exclusive otherwise.
I did make a strange observation though: when I first went into panel mode to test this, all the controller values for MOD 1 and 2 was set to 97%. I've never made those settings, so that could be from some buggy'ish initial values(?) Running FW 1.2.0.
I tried this and it works fine.mikeh11 wrote:The Sub 37 manual on page 14 says:I started writing a note saying that maybe you found a bug, because in my attempts to recreate the problem, I also thought that the pitch-bend was "lost" in a power down. In duplicating my steps, I find that it works as advertised. Hmmm.In PANEL mode, the sound you hear reflects the current position of the front-panel knobs and buttons. Parameters in this mode (other than the knobs) are saved in a special buffer, so you can pre-set the panel to retain any non-knob settings you choose.
Went to panel mode.
@voyager0500 can you do a thorough test with a list like this one to see if someone else can reproduce your problem? I tried what you told on June 20 and it works perfectly as well
http://audiotecna.info
test1@mikeh11 try doing an innit patch on the panel mode and change the pitch wheel bend ammounts and control ammounts and switch off the synth without going into preset mode and see if that works
- init preset (press and hold Panel button)
- mod2 control button
- changed mod/press/velo control amts
- preset edit (press and hold Preset button)
- changed pb depths
- immediate power off
- wait 1 min
- power on
- press Panel button
- all settings still there
- still good the next day, too!
Seems OK?
