Hey all,
Just bought a Sub37 a few days ago. First thing I did was update the firmware and download the editor. When the firmware update completed, I tried opening the Standalone app and it says it can't connect and to check MIDI settings on the instrument. However, if I open Logic and the Sub37 VST editor, it connects and syncs perfectly fine.. I've tried deleting the standalone app and reinstalling, but still no luck. Any ideas? I'd like to be able to use the editor without opening a DAW every time.
Sub37 Editor Standalone Not Working, VST works
Re: Sub37 Editor Standalone Not Working, VST works
I have the same problem. Standalone app does not detect the Sub 37 but the AU running in Ableton Live works fine.
Would like to run the Editor without having lo launch Live always. Using OS X.
The same problem. Editor cannot connect to the hardware.
But in Logic Pro X editor works perfect.
Taking your post, letter for letter. You updated the firmware, then downloaded and installed the editor. Did you install the new firmware that came with the editor?callahanryan12 wrote:Hey all,
Live Setup:
MacBook Pro, OSX 10.11, MOTU MicroBook II, Push 2, SoftStep 2, NI Maschine 2, Ableton Live Suite 9.6
Korg Kronos 88, Moog Sub 37, Moog Slim Phatty, Roland GAIA, Korg minilogue
Check out editor MIDI input/output settings.
Should be:
Setup -> Editor Settings -> Midi Input -> Moog Sub 37
Setup -> Editor Settings -> Midi Outout -> Moog Sub 37
Should be:
Guys using USB hubs? I've noticed that it can cause sometimes connection errors with certain synths and their softwares.
I guess this would actually need its own topic but I'll try it here. I have the same issue like the people above but the other way around: The stand alone works fine but the VST doesn't.
The strange thing it that it actually DID work from the day the editor came out until today. It says it cannot find the hardware when used in Ableton.
I tried it with different USB cables and with DIN MIDI. All configurations worked perfectly in stand alone mod but did not in Ableton VST mod.
Any ideas? would be really cool as I already started several projects with the editor.
Thanks a lot!!!
Thanks a lot!!!
I actually got it working! This was my problem. For some reason in the standalone app Moog Sub 37 was in red, and I clicked the dropdown and selected Sub 37 again and it suddenly works. Weird bug but it works now!Kaulins wrote:Check out editor MIDI input/output settings.
Should be:
