Disable save preset with double click the master
M-Prod
Post by M-Prod » Sat Nov 22, 2014 6:00 pm
Double click on the master button saves the preset in the current slot. Very often is accidently overwrite a patch this way. Can i disable it?
I'm on V3.6
RL
Re: Disable save preset with double click the master
Post by RL » Sat Nov 22, 2014 7:59 pm
No, sorry. Not yet...
RichardK
Post by RichardK » Mon Nov 24, 2014 4:48 pm
I've seen a couple of references to 3.6 - I have 3.5? I haven't bought the field upgrade yet though so I still have the smaller preset storage.
Some things hurt more than cars & girls
Sound: Voyager PE, VX-351, CP-251; AIRA, MiniNova, Karma, Reason, Maschine, OP-1
Control: Zaquencer, Reason, Panorama P4
yesman
Post by yesman » Mon Nov 24, 2014 8:04 pm
I'd like to be able to disable the preset scroll function using the ext. in pot. I would prefer to be able to alter the level when the input is off, so that I can then kick in the ext. signal at preset levels.
RL
Post by RL » Tue Dec 02, 2014 10:33 am
Hi all,
@M-Prod:
I made a change in the MASTER Storage Mode(s) menu, now you can switch on/off this function.
@yesman:
there's also a change in the PANEL Quick Mode menu, now you can switch on/off the external audio pot function too.
Here you can get the 3.6 version for the regular Voyager:
http://www.moogmusic.de/bank_A_360.syx
http://www.moogmusic.de/bank_B_360.syx
http://www.moogmusic.de/bank_C_360.syx
http://www.moogmusic.de/bank_D_360.syx
Here you can get the 3.6 version for the XL Voyager:
http://www.moogmusic.de/XL_bank_A_360.syx
http://www.moogmusic.de/XL_bank_B_360.syx
http://www.moogmusic.de/XL_bank_C_360.syx
http://www.moogmusic.de/XL_bank_D_360.syx
And here you can get the 3.6 version for the RME Voyager:
http://www.moogmusic.de/RME_bank_A_360.syx
http://www.moogmusic.de/RME_bank_B_360.syx
http://www.moogmusic.de/RME_bank_C_360.syx
http://www.moogmusic.de/RME_bank_D_360.syx
Here is a little explanation how to transfer the files to the Voyager:
You need MIDIOX for a Windows computer (sorry, I don't have a MAC):
http://www.midiox.com
Here are the settings in MIDIOX:
To transfer a file to the Voyager select the file by the right mouse button as you can see on the photo:
You should see this when you've pressed the right button:
The update file order is:
1) go to the MASTER page "Receive Update" and send bank "B".
2) then if the Voyager asks for bank "D" leave "NO" and press ENTER.
3) in the MASTER menu go to "Receive Update" and send bank "A".
4) now when the Voyager asks for bank "C" select "YES" and ENTER and
send bank "C" to the Voyager. Do the same thing with bank "D".
Check after the update whether the boot and the system numbers are the same
in the MASTER "Software Version" menu.
Have fun,
Rudi
kamilof
Post by kamilof » Tue Dec 02, 2014 12:04 pm
Thanks a lot Rudi!! Going to try 3.6 right away on my Voyager!
yesman
Post by yesman » Wed Dec 03, 2014 6:47 pm
Thanks Rudi,
Thats great!
RichardK
Post by RichardK » Fri Dec 05, 2014 7:00 pm
Thankyou! All updated - now I need to sort the field upgrade and get that extra patch storage!
yesman
Post by yesman » Sat Dec 06, 2014 12:06 pm
OK, I seem to be having a bit of a problem with the update. I can see that Midiox is sending data out from my FF440. I have the V set-up to receive the update & I seem to have loaded Bank B as the V is now asking for Bank A. I send that & the V is not doing anything. Any help would br greatly appreciated. This is running under Win7 Pro 64bit.
yesman
Post by yesman » Sat Dec 06, 2014 12:26 pm
Problem solved, bad midi cable!@#$%*
slirak
Post by slirak » Mon Dec 22, 2014 10:22 am
Unfortunately, this update screwed my Voyager SE. It now boots into sweet nothing. The LED's and the display lights up, but the display just shows black pixels all over.
I guess there's no way out of this, except taking it to an authorized repair service?
RL
Post by RL » Thu Dec 25, 2014 6:22 am
slirak wrote:Unfortunately, this update screwed my Voyager SE. It now boots into sweet nothing. The LED's and the display lights up, but the display just shows black pixels all over.
Hi slirak,
To reset the factory settings:
Power off the Voyager
Press and hold the -1 and the +1 buttons
Power on the Voyager
Release the buttons
Then please try this:
Press and hold the ENTER and the CURSOR buttons
Switch on the Voyager
Release the ENTER and the CURSOR buttons
Press ENTER
Now you are in the boot system
If the display is still dark, you have to change the LCD contrast.
Is it possible to get the MASTER LED on when you press the MASTER button?
If it's possible then press ENTER when the MASTER LED is selected and then press the +1 button ten or more times to get a contrast change of the display.
Rudi
slirak
Post by slirak » Thu Dec 25, 2014 3:42 pm
Thank you so very much Rudi!
I can now boot and it says v 3.6 on the boot screen. Apparently though, I'm running a minimal OS now? The synth's playable, but a lot of the menu options are missing.
After a second re-boot, there's a message saying "The operating system has to be re-loaded. Re-load Bank C?".
Since I'm scared to mess things up further, I've left the Voyager on at this point. Should I proceed and reload Bank C, or is there another procedure to follow?
Regards
/Jonas
RL
Post by RL » Thu Dec 25, 2014 5:26 pm
Hi slirak,
make this after power on:
when the Voyager asks for bank "C" leave "NO" and press ENTER.
Maybe after the complete update the display is dark again, then do it as I described above.
Have fun,
Rudi
slirak
Post by slirak » Thu Dec 25, 2014 6:14 pm
Thanks again Rudi, this worked perfectly and my Voyager is fully back to life now! Both the OS and Boot version says 3.6.
Is there any updated documentation for the new features?
Regards
/Jonas
