Is there version 3.6 online? The Moog Voyager sound editor only updates to 3.5.
My Voyager XL has stop sending any audio. The keys still send midi signal. I'm afraid I may have jacked up my software and am looking to reset to factory.
I'm using a Macbook Pro and PreSonus Audiobox USB midi interface.
Any thoughts would be most appreciated. I've finally got a space I can jam out in. I turn on my Moog and NOTHING!
Thanks,
Jason
Reloading System 3.6 on Voyager XL
- RL
Re: Reloading System 3.6 on Voyager XL
Hi Jason,
I don't know why Moogmusic removed the software for the XL - here you can download the 3.6 for the XL:
http://www.moogmusic.de/Voyager_keyboard_3_6.zip
Please reload the files in this order:
MASTER menu Receive Update
Send file "bank_A_360.syx" to the XL
The Voyager will ask for Bank C...
Select "YES" and send the file "bank_C_360.syx" to the XL
The Voyager will ask for Bank D...
Select "YES" and send the file "bank_D_360.syx" to the XL
Then the normal operating system should start.
Go to MASTER menu Receive Update
Send file "bank_B_360.syx" to the XL
Again select "YES" and send the file "bank_D_360.syx" to the XL
That should work!
Have fun,
Rudi
That should work!
Have fun,
Rudi
But, you could also be local off in the menu and it will ignore the keyboard.
- RL
Hi "Just me",
in an other thread he wrote: "EG, there is no longer a Copyright Info and several menu items are marked **** RESERVED ****".
So ,I think, he deleted Bank D of the operating system.
Didn't see that.
I lost track of the difference of 3.6 firmware compared to the normal Voyager's 3.5 firmware. What was changed?
Sequence:
Sequence:
The link above, for OS 3.6, is now dead. Could anyone please tell me where I might get this now.
Thanks in advance.
Thanks in advance.
Look at the post "Can't find a way to stop sending MIDI CC", on Sat sep 20, 2014 2:10pm, there is link...
Thanks for that -found it.
Sounds iike maybe local control has been turned off. I have found that when i boot up my Cakewalk Sonar program while the Voyager is already on, Cakewalk sends some sort of CC message telling the voyager to disable local control... it's annoying but when i manually re-enable local control in the "Master" menu, all is well. Perhaps something in your midi chain is sending out unwanted instructions to disable local control.
