Wood damaged, which varnish?
fietspomp
Post by fietspomp » Sun Oct 27, 2013 8:08 am
My Voyager has been damage on the wood side panel. I want to abrade and polish it again. But what kind of varnish or lac would I need to use? I like tot try to avoid to abrade all of the wood of the entire panel, just want to repair the damaged part, but then I would need a varnish coming as close as possible to the original. Any ideas?
Could any of the Moog engineers help me with this?
Ledbetter
Re: Wood damaged, which varnish?
Post by Ledbetter » Sun Oct 27, 2013 1:21 pm
Can you post a pic?
fietspomp
Post by fietspomp » Sun Oct 27, 2013 3:08 pm
Hmm, just tried to upload a picture. Get the message "Sorry, the board attachment quota has been reached'. No idea how to delete previous uploads.
Will try again later.
Vsyevolod
Post by Vsyevolod » Sun Oct 27, 2013 6:38 pm
Use an online free photo sharing site, like Photobucket, then link to it.
Stephen
fietspomp
Post by fietspomp » Mon Oct 28, 2013 3:53 am
Ledbetter
Post by Ledbetter » Mon Oct 28, 2013 3:09 pm
I see.
You should probably send that pic to Moog and get a recommendation. Howard's makes a finish restorer that might work if the abrasion is not too deep. Otherwise, I would tape off all the metal and plastic, sand with 200 then 400 grit sandpaper. Wipe well with 100% mineral spirits (not paint thinner or turpentine) and wipe on an oil finish like Tung Oil very light coat to start. You can put more coats on if needed to match. If you aren't experienced in finishing wood you might want to get someone who is to do this.
fietspomp
Post by fietspomp » Thu Oct 31, 2013 8:03 am
So the Voyagers are not treated with lac or varnish but with oil?
Cpt Beardheart
Post by Cpt Beardheart » Thu Oct 31, 2013 2:47 pm
It looks and feels like an oil finish to me. I would recommend something other than Tung oil. In my experience, Tung oil takes a very long time to cure. Danish oil is what I prefer for oil finishes. Though either one will get you there.
Ledbetter
Post by Ledbetter » Thu Oct 31, 2013 3:14 pm
Watco makes a great Danish oil finish, which would work fine. Sometimes Tung Oil is mixed with components to make it dry faster. Without those components, it takes a couple of days. Again, I recommend that you ask Moog what they use for the original finish. Post the info here, if you don't mind. Good luck.
fietspomp
Post by fietspomp » Sat Nov 02, 2013 5:31 am
I sent a mail to Moog with the question what''s best to use. If I get an answer, I will inform you guys.
Cpt Beardheart
Post by Cpt Beardheart » Fri Nov 08, 2013 12:23 pm
For what it's worth, I think the scrape looks pretty cool. That's a synth that's been places and seen things.
timmyyorston
Post by timmyyorston » Tue Nov 12, 2013 8:38 pm
I would say do not sand it while it is attached to the synth. Take it off lest sawdust gets in your works, then when it is dry put it back on. Just sayin'
fietspomp
Post by fietspomp » Fri Nov 15, 2013 8:43 am
No response yet by Moog support :( :( :( :(
djwillderness
Post by djwillderness » Thu Dec 03, 2020 7:59 pm
bump...anyone know what kind of varnish on the Voyager Performer edition? Dinged mine want to touch it up
