With a menu option for the original behavior, timed with the note on? Sometimes, I like it to swing a bit.Amos wrote:this is definitely to be implemented! better late than neverVitja wrote:And another thing I also recommend is steady ARP with MIDI clock without offset, so you can hit note out of beat, but ARP stays in groove. Otherwise you really need to focus to play first note tight in sync and than you need to play legato if you want it to sound musical and in tempo.
Amos: LP/Slim Firmware Suggestions
Re: Amos: LP/SP Firmware Suggestions
- stiiiiiiive
Have I asked for loopable envelopes?
Since we don't have a VCA mod destinations this would be awesome!
+1 for loopable envelopes!
Gear:Slim Phatty, Arturia Minibrute, Casio MT-600, MF-101,MF-102,MF104Z,MP-201,CP-251,Ibanez John Scofield, PRS custom 24, circuit bent Kawai R-100,Circuit Bent Roland TR-505, Boss Dr55, Akai MPK 25, Ensoniq DP/4, RME Fireface 800, tons of guitar effects.
- Bald Eagle
I thought the filter and amp envelopes on the SP are already loopable via hidden parameters.Vitja wrote:Since we don't have a VCA mod destinations this would be awesome!
I'd love to be able to set filter cutoff keyboard tracking beyond 100%. A multiplier in the menu to set the range of the KB tracking 100%, 200%, or 400% would be great!
- stiiiiiiive
SP stands for Slim Phatty here. A related topic...Bald Eagle wrote:I thought the filter and amp envelopes on the SP are already loopable via hidden parameters.Vitja wrote:Since we don't have a VCA mod destinations this would be awesome!
Re: Amos: LP/Slim Firmware Suggestions
Hey Amos - really looking forward to the next Slim update - you guys are awesome. I think you already know about this one, but there is a bug in saving LFO clock divisions to presets - they always end up back at their defaults. Also, as someone else has mentioned, assignable MIDI CC numbers would be out-of-this-world amazing - some controllers are more limited than others in their MIDI flexibility and this would open HUGE doors for me on this instrument. Sincere thanks for all that you do.
Cheers!
Cheers!
The Phatty's seem to be missing this option.
LFO SYNC MODE:Internal Master
LFO SYNC MODE:Internal Independent
ARPEGG MODE:Internal Master
ARPEGG MODE:Internal Independent
In Master mode the LFO and Apeggiator would would be synced to one internal clock, adjusted by the rate knob or tap tempo. LFO and ARPEGG should maintain independent clock divisions.
Internal Independent would be the current operation.
Thanks for the consideration
Little Phatty Stage II, Rogue, Cp-251, Soldering Iron
How about an additional setting in the lfo section which lets you round off the edges of the S/H waveform?
+1Djones wrote:How about an additional setting in the lfo section which lets you round off the edges of the S/H waveform?
The phatty clock handling definitely needs work. I hope in general, Amos focuses on improving the current feature implementation over adding new bells and whistles.Benjamin AM wrote:The Phatty's seem to be missing this option.
Loopable env, osc trig sync, ect. are all great features to add. But if it comes down to limited time to work on the code, I'd like to see the user experience of the current features smoothed out a bit.
#1) clean up the few remaining bugs
After that menus, CC tables, and clock implementation need some work.
Pot mapping to several destinations from same knob.
- misterpete
What is a "loop able" envelope?
Do you mean the REPEAT style "AMPLIFIER ENVELOPE REPEAT" currently found on the SubPhatty?
There's a similar "REPEAT" function on the Envelope Generator on the Telemetry/Vostoks from Analogue Solutions, which you can access directly by pulling out a hardware knob though it's not patched or normalled into the VCA so you can send it to any destination — i think it's modelled after EMS synth/Putney
stiiiiiiive wrote:Have I asked for loopable envelopes?
Please Call Me, PETE
- stiiiiiiive
All correct Pete
hello, here are my suggestions for sub phatty options: 1. I'd like the option to bypass mod.wheel so that PWM, pitch or filter can be modulated independent of the wheel position. 2. mod.wheel controls filter cutoff instead of filter mod.depth. 3. pitch bend on/off for osc 1 & 2. 4. hold note when MIDI CC sustain is sent to Sub phatty. 5. Option to switch modulation source to filter env. individually for filter, PWM & pitch.
/jocks13 in Sweden
/jocks13 in Sweden
