Hey everyone cool forum,
The 104M Manual lists "Pitch Bend Amount" as one of the functions of the delay that can be accessed via CC messages..There are specific values that can be sent over CC#83 to select various semitone amounts..
I'm successfully sending CC to the 104M and other foogers for a bunch of other controls, however nothing happens when I try to use this Pitch Bend Amount function..
Is this function supposed to be for precise control of the LFO Amount?! or is it something else?
Any advice much appreciated thanks!
104M Pitch Bend
Re: 104M Pitch Bend
Beats me. You should try calling Moog Support.
Re: 104M Pitch Bend
I have the ClusterFlux, which has the same control. You are correct that sending this value produces no audible change. It does however set the maximum of the pitchbend control. You need to be using pitchbend from a DAW or keyboard to hear the limit reached.
I send pitchbend from animoog and that seems to work... It's a neat feature! It controls the pitch of the delayed signal. If you are playing in note mode, you can then bend the note as you like, or shift the delay time similar to spinning the knob. At least this way you can get some tuned limits.
Re: 104M Pitch Bend
Thanks!Alien8 wrote:If you are playing in note mode, you can then bend the note as you like, or shift the delay time similar to spinning the knob. At least this way you can get some tuned limits.
![Smile :)](./images/smilies/icon_smile.gif)
