patches that create singing vowels ?
Re: patches that create singing vowels ?
see Allen Strange's Electronic Music System page 158 Figure 9.44 Simulated vowel formants
patch is
Oscillator to multi to 3x Bandpass and 3x VCA to mixer
patch is
Me asking some what different question - How you doing with vowels as per the info suggested? Ultimately where you arrived?
- _DemonDan_
There are lots of guitar processors that have Vowel effects
(Korg's Pandora and EHX Talking Pedal come to mind).
But there's a Dual (true) Analog Filter pedal called "Wahoo"
by Sonuus that can do many things including vowel simulation:
http://www.sweetwater.com/store/detail/Wahoo
http://www.sonuus.com/products_wahoo.html
Each of its multimode filters can be independently controlled by:
Foot Pedal, LFO, Envelope, or Pitch (!)
http://www.sonuus.com/products_wahoo_editor.html
_ _DemonDan_ _
Yes..getting there. But its a lot of hit and miss, using the 3C limitations of the early 70's I don't want to use new gizmos on the system so am building an x-y pedal which I think should achieve the Tomita type vowels etc.MusicoNova wrote:Me asking some what different question - How you doing with vowels as per the info suggested? Ultimately where you arrived?
ebo wrote:see Allen Strange's Electronic Music System page 158 Figure 9.44 Simulated vowel formants
patch is
I didn't know of this book..Amazon have it for......£250 !!!!!
I think there is a PDF...does anyone have a link?
+ 1 to this! I've been trying to get my hands on the pdf, but to no avail! Anybody have it?rarecomponent wrote:ebo wrote:see Allen Strange's Electronic Music System page 158 Figure 9.44 Simulated vowel formants
patch is
THE GOLDEN MINIMOOG VOYAGER #31
- misterpete
Hi ebo!
can you get that Holy Grail converted to a .pdf somehow?
maybe if we pitch in to cover your cost we can it into the knobtweak archives?
patch is
Please Call Me, PETE
- misterpete
misterpete wrote:Hi ebo!
maybe if we pitch in to cover the cost we can get it into the knobtweak archives?
patch is
In a recent video test of the new Happy Nerding Fun VCF I happened on some vocal sounding "whoa wow" sounds. Jump to about 7:05: http://youtu.be/X114GA1280s
There is a new module called the RB1Robotto that is coming out (soon?) by soundmachines that is designed for vocal singing! I really want one! Here is an early test byt the manufacturer, 'vocal' stuff starts at about 1:30 http://youtu.be/lpkUkJ1fwIc
John L Rice
- Kevin Lightner
Certain vowels can be realized by running one oscillator through a filter, then using another oscillator (usually higher pitched) to FM the filter via CV inputs.
The modulation waveform is often best being a square, but PWM can greatly affect the outcome and is desirable to have control over.
Filter freq, resonance and modulating osc freq and waveform are tweaked until the desired vocal.
With this above, I've been able to make a human sounding A, E or I.
Kevin ...thats a superb tip...Works a treat! I'm getting those special timbres....any more patch tips there?
I do know that Kevin's tips will work on a Voyager. Years ago I did a atonal piece called "An Aibo Libido" on the Voyager - I was just tweaking the panel while recording and I got a bunch of formant sounds from that. Unfortunately that was before the OS had MIDI CC control of the panel, otherwise I would've captured tweaking via MIDI.
- Kevin Lightner
Cool that you got that happening.
Different filters can vary a lot.
The only further advice I could give you've probably already tried: vary the modulation depth to the VCF.
Maybe using an already hardsync'd waveform (for either audio or modulation) could make some interesting variations?
That was definitely one of my tricksKevin Lightner wrote:Maybe using an already hardsync'd waveform (for either audio or modulation) could make some interesting variations?
I have created a vowel patch with the Sub Phatty, believe it not.
It is utilized here in the first demo for my other project, The Black Sacrament - a Skyrim-influenced Worship / Ritual / Drone project:
http://soundcloud.com/theblacksacrament/encantation
This is likely to be the most "mellow", albeit still eerie, piece that you can come to expect from this project. It is called, "A Child's Conjuring".
Enjoy.
(All synthesis performed with a Sub Phatty.)
Enjoy.
Moog Sub 37 (#0133), Ibanez M80M, & Doomy Bow
MF-102 • MF-103 • MF-105m • KE Kommander • MHI B:a (Germ. w/EQ mod) • Strymon Timeline
Previous: Model D, Taurus, Taurus III, Little Phatty SE II (Solar Edition w/CV Out mod), Sub Phatty
