LP Arpeggiator midi sync (with accurate trig points)
Everything Phatty.
Johanivansson
Post by Johanivansson » Sat Apr 06, 2013 11:32 am
Hi!
Is it possible to sync the tempo via midi and also sync the trig points? For example, if I choose 1/16 subdivision, it will automatically sync to the next 16th note? I would like to be able to play 16th note basses, but feel very uncomfortable with having to be 100% accurate on the first note...
Possible?
Sir Nose
Re: LP Arpeggiator midi sync (with accurate trig points)
Post by Sir Nose » Sat Apr 06, 2013 12:25 pm
Coming soon!!!
http://forum.moogmusic.com/viewtopic.ph ... 37#p115700
From Amos, the Moog employee who writes the phatty code:
Amos wrote:
Vitja wrote:It would be useful to turn off the arp retrigger when using external clock, so all the arps can be played on beat.
Sometimes is hard to have all arps and LFOs in sync with retrigger on. I know you can turn it off for LFO, but I can't find this option for arp.
This is definitely coming in the next update! New Arp mode, re-sync only to MIDI Start / keep that same downbeat timing thereafter. Long overdue...
Johanivansson
Post by Johanivansson » Sun Apr 07, 2013 9:15 am
That's great! Is there any info regarding when the next update is coming?
digilog
Post by digilog » Mon Apr 08, 2013 12:53 am
Great news, really looking forward to this feature.
Sofine
Post by Sofine » Mon Apr 08, 2013 6:51 am
Great!!! This will be a great feature
Slight derail, though somewhat related... I remember being able to use the mod wheel to change the arp clock divider, e.g., 1/2 to 1/4 to 1/8 etc using the wheel (or mod amount knob), has this been removed in firmware 3.1 as I can't find it anywhere?
