Hi
My System is Win7 x64
I am using the Minitaur Editor in conjunction with midiox/midiyoke, so I can use it whilst using the DAW at the same time.
I connected the Minitaur output with yoke1 which in turn is connected to the DAW and the editor as input. The DAW and the editor then use yoke2 as output, beeing connected to the input of the Minitaur. This worked great for some time. I was able to use the editor almost as well as if it was a plugin in my DAW. Loading and saving presets worked like a charm and I could easily change the 'under the hood' settings whilst playing and recording the Minitaur in my DAW. This worked well with all previous versions of the editor, but it changed with the new version (1_7_2012).
When I opened that editor the first time I was excited about the mass of new presets to get inspired by, so I tryed to load one of 'em up. That's when I had my first bluescreen. Beeing stubborn, I tried a few more times whith always the same result. I crashed the system three times - enough to corrupt system data, so I rebuild the filesystem and reinstalled all the VCredists, just to be sure.
Now I am not even able to use the editor on that computer. Everytime I start it, I get a short flash of the editor window followed by some message saying:
Microsoft Visual C++ Library
This application has requested the Runtime to terminate it in an unusual way.
Please contact the appliaction's support team for more information.
The editor is working great on another computer with also win x64. The new presets are pure win
