Good evening to everyone.
I'm a Moog noob and I have a problem with the MIDI in of my Little Phatty.
I was playing it via Ableton Live, with the MIDI out of my EDIROL UA 25 audio device, and everything was going right until I switched off the Moog.
Then I re-switched on it but didn't read the midi signal anymore, no way.
Someone can help me??
thankx!
Joe
Little phatty stage 2 Midi sync problem
Re: Little phatty stage 2 Midi sync problem
First off, welcome to the Forum! Secondly, this should be in the LP subforum, not the Moog guitar forum. Don't worry, it happens.
I never had good luck with MIDI, on any machine. However, did you try disconnecting and reconnecting the MIDI cable? Refreshing Ableton? Are you running the latest device drivers for the edirol? If not, update the drivers. Those would be my suggestions.
