tuning, osc 1 pitch wandering
Posted: Tue Jul 27, 2010 1:59 am
by nato
I'm completely new to Moogs so I bought a used LP from a music store last week to learn more. (This LP is a few years old I think, no USB, gray/black, "Little Phatty (R) analog synthesizer".) I'm very impressed by the sound but I have noticed a tuning problem that has persisted after the calibration sequences. After being powered up >1 hr, I still have a very uneven osc 1 pitch. The problem is most pronounced at the "calibration preset" tone (osc 1 only). The tone is uninterrupted but the pitch wanders broadly, 50-60 cents at 16', several semitones at the 2' setting. The pitch varies unpredictably, sounding like a gnat buzzing or a tea kettle on high notes. When I zero "osc 1 level" and listen to osc 2 alone, it is the even tone I expect. This behavior is consistent whether I've set the LP to "auto tune" or fine tune. I am making no other changes to the panel. This wavering of osc 1 sometimes goes away which is encouraging but then returns suddenly with a seemingly random panel change and no setting change will correct it again. This happens whether I listen through the headphones jack or through the audio out. The preset light has not changed to red when I hear this sound (though my preset light sometimes turns red on its own). My question: does this sound like a factory repair candidate? Is there something else I can try first?
Re: tuning, osc 1 pitch wandering
Posted: Tue Jul 27, 2010 10:51 am
by Sir Nose
It sounds like you hit everything on the normal try this 1st checklist. I would run a calibration one more time if you haven't already, make sure it is performed in the same order as stated in the manual. There could be signal coming from the pitchbend wheel causing the fluctuation. Check to see if OSC 2 also drifts, turn OSC 1 all the way down, tune OSC 2 and see if it drifts. Does it drift tune up and down the keyboard or does it drift for a single frequency held over time?
It does sound like a repair job though. Before you look into getting it repaired, email moogsupport, they will have a more comprehensive checklist. They have helped many people at home to avoid having to send in their instrument. If you have to send it in anyway you may want to consider CV out mod while it's there, depending on your needs.
Posted: Tue Jul 27, 2010 9:14 pm
by nato
Thank you for the response. This is an exceptional forum! To answer your questions: 1) it drifts around one frequency but I don't know what frequency it will be until I turn it on. The C keys on the calibration preset have on different days sounded G#, Eb, a very flat F (too far from C to be corrected with fine tune). When I keep the LP on the calibration preset but bring down Osc 1 level and turn up Osc 2 level, the Osc 2 tone is always an even C. I'll rerun the calibrations and if that fails email moogsupport. If there's any generally useful news I'll post it. Thanks again!
Posted: Wed Jul 28, 2010 12:37 am
by dlearyus
this couldnt be related to a grounding issue could it?
seems that one has mystifyed alot of people in past
as it manifests itself in all kinds of intermittent weird
effects.
just a thought before rushing into repairs etc.
DL
Posted: Wed Jul 28, 2010 7:48 am
by Sir Nose
Definately make sure the outlet the LP is plugged into is grounded. With OSC 1 drifting on one frequency, while OSC 2 is stable, it sounds like a repair job.
Posted: Wed Jul 28, 2010 8:33 am
by tript
this sounds like a grounding issue.
Posted: Wed Jul 28, 2010 9:10 pm
by nato
Thank you for the responses. I tested my outlet and it's definitely grounded (as it should be). I've been in touch with moog support so I think this LP will be traveling soon. I'll give the CV out mod some thought.
Posted: Tue Aug 03, 2010 8:01 pm
by praxisaxis
"My question: does this sound like a factory repair candidate? Is there something else I can try first?"
It sounds very much like you'll have to get it repaired. But perhaps try the factory reset? I guess you have already... I only suggest it because that did away with some minor weirdness I was experiencing shortly after I purchased the instrument.
Posted: Tue Aug 10, 2010 11:26 pm
by nato
Thanks. I also tried a factory reset and that didn't help. I ended up exchanging it for a new LP so I'm not sure what the problem was.
