Can I Run My Guitar Through The LP's Filter?
yes or no? I heard you could do this with the Voyager. If so how?
If the brain was simple enough that we could understand it, we'd be simple enough that we couldn't understand it.
Re: Can I Run My Guitar Through The LP's Filter?
yes. audio in.
Moog Voyager RME / Moog LP SE 2 / Nord Rack 1 / Microkorg / Korg ER-1 / Triggerfinger / Rocktron Banshee talk box / Ableton live / Guru / Lots of non-electric musical instruments.
Firstly, chuck a dummy lead (a patch lead with nothing attatched on the other end) into the cv/gate of the LP to keep the gate of the synth open.
Then plug your guitar into the audio in of the LP. You may want to turn down both oscillators on the LP as well, as they will continue to ring whilst the gate is open. You can then run the guitar through the LP's filter.
Little Phatty Stage II #3602, MoogerFooger CP-251 #1785
MF-103 12 Stage Phaser #6093, MF-104m Analog Delay #0301
My band: www.facebook.com/InstantMorning
One of the guys posted a brief tutorial on how to go about this late last year. The biggest challenge is getting the Filter cutoff to open/close via envelope when you strike a string/chord on your guitar.
You can certainly do this via expression pedal, but it's not very precise unless you've got practice with a wah pedal. (spring loaded is best if you set the pots correctly).
Ultimately, you'll benefit from a instrument interface (such as the synth.com module) that kicks a trigger/gate at a certain amplitude, or an envelope follower as present in a 101 or a 107.
Messing with a LFO to drive the filter will certainly give more bang.
thanks so much! God Bless Dummy Plugs lol.
Derek
Derek
