My LP has sometimes some boring troubles :
the sound parameters are moving alone... I posted several about this point,
and some pleasant forumites told that it was certainly a ground or midi loop problems...
I tried to check that, but nothing changes...
yesterday, the problem came again,
and i noticed that it happens when midi cable and audio cable were wired on the synth.
When i disconnect the audio cable, no problem... BORING
so in my research, i read that some LP had problems with the metal case :
does someone knows how to make a mod that clean this trouble ????"The Voyager has a complete ground from the metal casing to the rest of the electronics and the LP doesn't"
Regards.
