Hi acorkos
Using the MIDI connection rather than the CV works perfect! Fantastic result! Thank you ever so much for!
MFB Step64 & LP Tribute
I have a similar problem with my MFB SEQ-02 module and the LP. The oscillators don't seem to track completely with the output. Anticipating the risk of high current drain I tried hooking it up through a Doepfer A-185 active bus access module with pretty much the same result.
The manual mentions that the oscillators are "nominally" 1v/octave. Does this mean that it's not supposed to track completely?
There's also a problem with the gate input on the LP. It seems to be "triggered" whenever i plug a cable in.
