Little Phatty Stage II CV Mod Tracking Problem
Everything Phatty.
amphonic
Post by amphonic » Fri Feb 05, 2010 1:00 am
I just received my new Little Phatty Stage II with the CV Output Mod. I am having problems using it to control a Synthesizers.com Oscillator. It seems like the Little Phatty is not actually sending 1volt/octave from the Pitch CV Out. A scale starting at E tracks to 25cents short of Eb one octave up. I hooked up my handy Multimeter and it confirms my suspicion, the Little Phatty is not sending 1 volt per octave. Is there a way to calibrate the Pitch CV Out to work at 1 volt per octave?
I am pretty frustrated at this point.
Amphonic
Sir Nose
Post by Sir Nose » Fri Feb 05, 2010 9:33 am
I wonder if it's because the LP functions at .95 or .97 volts/octave internally. Just a tad less than 1. When the CV out mod was proposed on this forum I ask if the CV out mod would send a full 1V/octave and was told yes. This was by a member of the forum quoting info he was given by Amos.
http://www.moogmusic.com/forum/viewtopi ... c&start=30
I sure hope it's not an issue with all CV out mods. I was hoping to get the CV out mod myself and would need to reconsider if it does not play well with others. If you have a CP-251, you should be able to play with the signal till it tracks properly. Just a lot of fiddling.
amphonic
Post by amphonic » Fri Feb 05, 2010 9:55 am
Thanks, I dont have a CP-251 but I do have a Signal Processor to fiddle with the CV, but that is not exactly a fun way to spend the evening. The CV mod is advertised as 1volt per octave on at the Moog Music site so I am guessing mine is not quite right or I am missing something obvious.
amphonic
Post by amphonic » Fri Feb 05, 2010 5:11 pm
Contacted Moog Support via email. It seems my Phatty was calibrated incorrectly. The fix should be pretty easy. A trim pot inside is used to adjust the volts per octave.
Sir Nose
Post by Sir Nose » Sat Feb 06, 2010 2:53 pm
nice :)
///OSS
Post by ///OSS » Sun Feb 07, 2010 3:15 pm
I wish that could be used for the CV ins as well, as I was never able to use the LP with other 1v/oct devices due to the .96 or .97 system it uses...sucks, as I did try with the CP but it was a pain in the arse. too sensitive and the notes just always sounded funny as it tracked up or down.
Little Phatty Stage #0042 - OS2.0 | CP-251 | MF-107 FreqBox | MF-102 Ring | MF-105B Bass MuRF
sine
Post by sine » Mon Feb 08, 2010 8:15 pm
amphonic wrote:Contacted Moog Support via email. It seems my Phatty was calibrated incorrectly. The fix should be pretty easy. A trim pot inside is used to adjust the volts per octave.
Can you do it yourself? If so, where is the trimmer and how do you get at it?
popgoblin
Re: Little Phatty Stage II CV Mod Tracking Problem
Post by popgoblin » Wed Oct 09, 2013 2:16 pm
Did anybody else experience problems with the CV out? My Stage II with factory installed CV out is way off...
br
Morten
Sir Nose
Post by Sir Nose » Thu Oct 10, 2013 1:27 pm
CV out should be 1v/oct.
CV in is .97v/oct or there abouts
popgoblin
Post by popgoblin » Fri Oct 11, 2013 9:10 am
My problem is more that, for instance, C3 is more like "F3" compaired to other equipment.... Can that be adjusted somehow? I've tried all the calibration rutines...
stiiiiiiive
Post by stiiiiiiive » Fri Oct 11, 2013 9:56 am
Hmm… F-based keyboard on the controlled equipment, isn't it?
popgoblin
Post by popgoblin » Mon Oct 14, 2013 8:13 am
F-based? Is that a thing?
My other CV-capable equipment (Elektron Analog Four, Anushri, ES-1) is waaaaay better calibrated, so the Little Phatty's... erhm "deviant" behavior surprises me....
stiiiiiiive
Post by stiiiiiiive » Mon Oct 14, 2013 4:28 pm
I saw this between some "regular" CV'd equipment and a MG-1, which is precisely F-based. As I understood your scale is right but offset by -say- a fourth (C to F), I had this idea.
Now if you think something is wrong, you definitely should write/phone to Moog techs.
popgoblin
Post by popgoblin » Tue Oct 15, 2013 10:05 am
will do - thank you for your input!
David Smyth
Re:
Post by David Smyth » Wed Oct 16, 2013 10:28 pm
///OSS wrote:I wish that could be used for the CV ins as well, as I was never able to use the LP with other 1v/oct devices due to the .96 or .97 system it uses...sucks, as I did try with the CP but it was a pain in the arse. too sensitive and the notes just always sounded funny as it tracked up or down.
When I sent my 3 Phattys (1x Little St. II, 2x Slim) to my local Moog tech (for another problem), I also got him to calibrate all of the Pitch CV In's to 1v/octave.
It can be done.. :D
David.
NZ
Minimoog Voyager XL, Little Phatty Stage II + CV Output Mod, 2x Slim Phatty, Minitaur, MP-201, EP-2, 2x CP-251, MF-102, MF-104M, MF-107
