Little Phatty Serial numbers
So... are LP serial numbers sequential from the start of the product line?
A Perfect Vacuum: http://www.myspace.com/aperfectvacuum
The Plateau Phase: http://www.myspace.com/plateauphase
Well, let's see...0001-1200 is the Tribute, which would suggest the Stage I started at 1201. I'm not sure when they switched to the Stage II but my Stage I is 1326, which tells me that I'm the 125th person to purchase a Stage I. On the other hand, all Stage II's have an additional 0 at the beginning of the number. So even if mine was the last Stage I made, the first Stage II would be 01327 if they truly are going in order. Now that I've confused myself, I'll leave you guys to work it out.Matt Friedman wrote:So something like 4,500 have been manufactured?
Sub 37 #000068, Minitaur, CP-251, MF-102&103, EHX #1 Echo, EHX Space Drums/Crash Pads, QSC GX-3, Miracle Pianos, Walking Stick ribbon controller, Synthutron.com, 1983 Hammond organ.
I guess the count starts at 0001 instead of 0000 just to show it's an analogue synth ...?
Little Phatty TE #1045 | Etherwave Theremin
Stockholm, Sweden - - - Listen at: assar.se
Yes, because the serial numbers for a digital synth would be like, 0000 followed by 0001, then 0010, then 0011, then 0100, followed by 0101, etc.Assar wrote:I guess the count starts at 0001 instead of 0000 just to show it's an analogue synth ...?
My Stage is #1326...no zeros at all.Brian G wrote:The Tribute SN is displayed as TE000xx of 1200 ,I am pretty sure the Stage started at 00001 or something like that.
As they say - there are 10 kinds of people, those who understands binary numbers and those who don't.Voltor07 wrote:Yes, because the serial numbers for a digital synth would be like, 0000 followed by 0001, then 0010, then 0011, then 0100, followed by 0101, etc.Assar wrote:I guess the count starts at 0001 instead of 0000 just to show it's an analogue synth ...?
There are two kinds of people.
Those who divide people into two types...
...& those who don't!
Little Phatty TE #1023 • Schrittmacher • Walking Stick ribbon • Korg microXL/Electribe MX/KaossPro • Sonnus G2M
MF-101 Filter • MF-102 Ring • MF-103 Phaser • MF-104Z Delay • MF-105 MuRF • MF-107 FreqBox • MF-108M Cluster • Etherwave
_/_/_/_/_/_/_/_/
_/_/_/_/_/_/_/_/
