Has anyone tried to make a emulation of the Moog Theremin sound?
I'm thinking of faking the theremin on our record, as we all aren't really capable of playing it perfectly;-)
Etherwave Theremin Patch
One way would be to use the filter in self-oscillation.
Turn Osc 1 and 2 Levels off. Turn Filter Resonance to max. Route LFO triangle to Filter. Right hand controls pitch with the Cutoff knob. Left hand triggers and adds vibrato with the Mod wheel.
Playing in tune would be about as hard as playing a Theremin though.
Most probably even hardersine wrote:One way would be to use the filter in self-oscillation.
Isn't one of the presets called somthing similar to Theremin?
I have edited that slightly and used it in a sort of Theremin-esque style in the outro of our tracks...
Listen here: http://www.last.fm/music/New+Modern+Angels/_/Girl
-Osc1 set to somewhere between saw and tri, iirc. LFO->pitch. I adjusted the glide rate manually while playing in order to make it sound ok.
But, hmm, I'm no "purist" as I wanted it to sound cool rather than exactly like a theremin...
Btw, I used a rather gritty spring reverb plugin, to make it sound "older"...
