HB3 wrote:I would like to pick and choose presets from the various banks available; do I need the editor librarian to do that? I can transmit single presents or entire banks from my sequencer, but I don't know if I can open up a bank and select various presets within it. Also, do I need the librarian software to save presets?
to save patches from the Little Phatty:
hook up a MIDI cable from the MIDI OUT on the Little Phatty to the MIDI IN on your computer (or whatever kind of MIDI interface you have hooked up to the computer).
If you haven't set up MidiOX already, go to the Options menu and click "Midi Devices."
in the MIDI devices window, click and highlight the correct input and output device.
This tells MidiOx what to use for sending and receiving. (Then click OK)
OK, now that MidiOx is set up, click on the View menu and choose SysEx.
A window will pop up called "SysEx view and scratchpad."
click on the Sysex menu in this window, and choose "Receive Manual Dump."
Now MidiOx is waiting for you to send something from the Little Phatty.
On the LP, press the Master button and then use the Value knob to scroll to the SysEx Menu.
you can use the Cursor button and Value knob to select different options on the SysEx menu.
Send Cur Preset sends only the currently-active patch, Send All Presets sends all 100 presets as one single bank file.
for the first time, I recommend sending the whole bank just so you have a backup copy of it on your computer.
when you have Send all presets selected, hit Enter, and you should start to see some data coming in on the computer screen. The Little Phatty will display the message "Sending All Presets."
When this message dissapears and the SysEx Menu is displayed again, the LIttle Phatty is done sending data. Click the "Done" button in MidiOx.
Now all the data is shown in the Display window, and it needs to be saved.
To save the data, click on the "Display window" menu in the Sysex view, and choose Save As.
Name the file and choose where you want to save it, just like you would in any Windows program. Ta-daa! done. This same process works if you are sending only a single preset (SEND CUR PRESET on the LP SysEx Menu). If you are sending only a single preset, it's a good idea to save the sysex file using the same name as the preset, so you can identify it easily.
To send patches to the Little Phatty from your computer:
You must (of course) connect a cable from the MIDI OUT on your computer to the MIDI IN jack on your Little Phatty.
Be aware that if you are sending a single preset, it will automatically replace whatever preset is currently active on your Little Phatty. So, before you send a preset as a sysEx file from your computer to the Little Phatty, go to Preset mode on the Little Phatty and use the Value knob to select the preset which you wish to replace.
In MidiOx, go back to the Sysex view window (View menu + choose Sysex, if you just opened the program)
Click on File and choose Send Sysex File.
select the sysex file you want to send, and hit OK.
The Little Phatty LCD display will show "Receiving Preset" very briefly, and then you should see the new preset displayed on the Little Phatty LCD. If you are sending a bank of all patches, the transfer will take slightly longer and all 100 presets in the Little Phatty will be replaced by the presets from the SysEx file.[/quote] Thanks Amos
Model D, Little Phatty Tribute w/cv, The Rogue, MF-102, CP-251, Animoog and Filtatron
