Yeah, thought I heard a Maytag in there.Amos wrote:The main snare sound is a brick through plate glass, and one of the other main "whack" sounds started as a washing machine being hurled into a giant steel drum the size of a railroad car.
Put all your LP mp3 songs here
Here's part 5 of my all Little Phatty series of songs. Overdubbed straight into protools, with a little bit of delay plug-in. http://hometown.aol.com/Acmesoundlab/Li ... ature5.mp3
More Little Phatty at http://hometown.aol.com/acmesoundlab/my ... index.html
Not a song. Just a test to see if I could come close to the original sound. I know I lack the skills that Wendy Carlos has. But it still sounds pretty good if I may say so myself.
http://web.comhem.se/tomrummet/stuff/moog_shining.mp3
Very cool Moomin, It definitely captures the Carlos vibe right away. You should put that preset up at the moogspace sight.
All Little Phatty music at:
Here's another all Little Phatty song. This is more loop-oriented than my usual stuff, though I couldn't resist hand playing most of it.
http://members.aol.com/acmesoundlab/PattiPhatty.mp3
Here's another sketch from this week. The first arpeggio with lots of reverb is Voyager... all other synth sounds are Little Phatty. Drums by Microtonic, and my djembe. Minimal but lush, I love the mood of this one.
geo-b-day-firstmix.mp3
Very cool song Amos. Here is another all Little Phatty tune I created down in the lab. http://members.aol.com/acmesoundlab/UpAndDown.mp3
More Little Phatty music at http://hometown.aol.com/acmesoundlab/my ... index.html
Yes, this is a good composition, Acme. I'm curious how you did it.acmesoundlab wrote:Very cool song Amos. Here is another all Little Phatty tune I created down in the lab. http://members.aol.com/acmesoundlab/UpAndDown.mp3
Thanks for all the positive feedback! As far as the technical questions, I did not use any sequencers. My LP was plugged into a Fender Steel-King amplifier, eq'd flat, then run out of it's direct-out into a protools m-box. I use the Steel-King for it's great spring reverb, which I pretty much use on everything. All the tracks were then hand played one at a time into protools. It's basically one A section repeated 3 times with a tag. Some of the tracks I just played 1 time, then cut and pasted them for the 2nd and 3rd sections. The only real manipulation I had to do, was for the main melody that happens during the 2nd and 3rd time thru. When I over-dubbed a harmony for the second time, and a octave doubling for the third time, the portamento times made them drag too far behind, so I shifted those whole tracks ahead a bit. Add a lot of delay plug-in, shake and bake, mix and serve.
Some great material in this thread. I'll post one although its more guitar than phatty.
Still a work in progress but you can get the idea.
http://www.onshorebreeze.com/music/inmotion.mp3
-Eric
-Eric
and another new track.
a cosmic sequence / with a screaming phatty near the end.
http://www.virb.com/von_haulshoven
