Moog Music Forum
Share Ideas and Pass the word
PLEASE HELP / Disappearing MIDI IN/OUT settings, no USB/MIDI
Everything Phatty.
Postby Lunnar » Tue Oct 31, 2017 7:06 am
Hello there!
I'm have a problem w/ my LPS2
LPS receives and sends no MIDI, and in the Master Menu - MIDI SETUP: MIDI IN/OUT options have disappeared...
All I see in midi setup: "All notes off / Local cntrl: ON / Midi Merge: OFF / Poly: OFF"
Several reboots/factory restarts haven’t helped.
Debug adapter - it did not help me too, the operating system is reinstalled (2.2 952), but midi&usb still do not work...
Please help!
Lunnar
Re: PLEASE HELP / Disappearing MIDI IN/OUT settings, no USB/
Postby bichuelo » Fri Nov 03, 2017 11:18 am
This happened to me some days ago, on my Slim Phatty
I had to do several resets as well as updating the firmware, then it finally worked.
Give it a second try
http://audiotecna.info
bichuelo
Postby lovvlovver » Fri Apr 27, 2018 5:32 pm
Hello, Lunnar!
Is there any progress to share about your problem? I have the exact same one.(( So I'd be really glad to hear some good news.)
bichuelo, did you manage to update firmware without functioning USB/MIDI? Or did it appear after a reset? I have a lot of presets on the synth I don't wanna lose if I don't have to, and I also do not want to render it completely unoperable by deleting the firmware and then not being able to upload it. My LPS2 otherwise works fine, and i keep using it without MIDI.
There's another thread on this forum describing similar issues, with quite a few people reporting in -- I wonder why haven't they posted here, but that's not the point, -- and nobody posted any solutions or any progress on the problem so far.
Really looking forward to hearing from anybody!
lovvlovver
Postby bichuelo » Wed May 02, 2018 12:57 am
I was able to update the firmware using the USB. IIRC, the MIDI DIN was the one which had dissapeared suddenly. I uploaded the firmware, made a factory reset and it worked perfectly afterwards
bichuelo
Postby lovvlovver » Mon May 07, 2018 8:41 am
bichuelo wrote:I was able to update the firmware using the USB. IIRC, the MIDI DIN was the one which had dissapeared suddenly. I uploaded the firmware, made a factory reset and it worked perfectly afterwards
Thanks for the reply! Both MIDI and USB I/O are absent/inactive on mine.((
lovvlovver
Return to Little Phatty & Slim Phatty Forum
Who is online
Users browsing this forum: Ahrefs [Bot], CommonCrawl [Bot] and 2 guests
