Firmware update OS 1.03 to 3.21
Hi!
I just bought a second hand MOOG Little phatty Stage I with the OS 1.03. Could anybody explane me please what is exactly the upgrade procedure?
I know that I have to do several upgrades step by step. I would like to update it to the ultimate software 3.21. I know that my OS is really old, but I need the arpeggiator function for my Little Phatty.
Thank you!
Thank you!
Re: Firmware update OS 1.03 to 3.21
Hi, I could not do the same procedure from the same reasons! There is a risk of crashing the entire system. Now I'm looking for the firmware to restore the firmware via jtag. All the hope for Amos!)
- stiiiiiiive
The arpegiator was introduced in OS2.0. There is document titled LPOS20_Addendum.pdf -not sure it is still available online but I can provide it if needed.
This document's Appendix A explains the update procedure. That will never been said enough: first save all your presets, then go slowly, step by step through the procedure. Some information about updating a Stage 1 LP in this topic.
For going to version 3.XX, there is a document titled LP_v2-v3_Update_Instructions_OSX.rtf. This one may be available online. It requires a supllementary step (loading a new boot loader).
Thank you very much!
But I can't find the 2.0 firmware update?
Does anybody know were could I find it?
- stiiiiiiive
There is a 2.21 there, not sure if you should install the 2.0 first
I also have doubt about it...
Does anybody have the v2.0 OS ?
The problem has been solved!!!
- stiiiiiiive
Ah! How?
At first I updated my LP from 1.03 to 2.21 without any problem .
And then , I followed the instructions to updated it from v.2.xto 3.x. First I had to install the BOOTLOADER to LP and then after restart the instrument (or without restart, I do not remember) the bootloader has installed the last OS;)
- stiiiiiiive
Great, you are up to date now
Hi Everybody
My second hand Little Phatty Tribute edition is running the os 1.03 and I would also like to update it to the latest. Could somebody explain me the whole procedure step by step? Which steps do i need to follow so that the whole instrument doesn't crash? Your help would be much appreciated!
Hi!
I think you should to write to Adam Pryor directly:
[email protected]
I think he would answer you in a few days.
[email protected]
Hi
I`ll write to him, thanks!
- stiiiiiiive
Thanks for the contact.
IIRC the latest Tribute OS is 1.04. Anyone, correct me.
