Hi there,
I am stoked with the opportunity to both globally and 'locally', per patch, being able to adjust arpeggiator settings.
As far as I know this can not be done for the LFO sync: I can sync the LFO to external midi globally but then this applies to every selected patch. Or am I overlooking a setting where I can do this?
With almost every sound I do like the LFO to sync to the Ableton Live rig we use on stage, but on one particular patch it needs to be out of sync.
cheers, Rodg.
LFO sync setting per patch
- stiiiiiiive
Re: LFO sync setting per patch
On the Little Phatty, it is impossible as far as I know. I use it in a couple of projects, one of which need the sync all the way and not the other: I have to remember to switch into the right mode.
ok, so I won't look further. next question pops up in my head: would it be possible to control that setting (LFO sync source) with a MIDI control message?
- stiiiiiiive
Just check the online manual MIDI charts
EDIT - from the manual :
Name: LFO SYNC SOURCE
Description: Selects the LFO synchronization source
CC#: 102
Values: 0 (INT), 64 (MIDI CLK)
CC#: 102
bam, that's what I need. Now I can program the sync source from the ableton project! thanks a million.
- stiiiiiiive
Hallelujah!
