Moog Music Forum
Share Ideas and Pass the word
Random mode on Sub 37 sequencer
Everything Phatty.
Postby ziggomatic » Wed Sep 07, 2016 1:30 pm
that'd be cool, right? :D
ziggomatic
Re: Random mode on Sub 37 sequencer
Postby Chimponaut » Mon Sep 12, 2016 4:04 pm
No "random mode" but the editor software can already do this. You can randomize the preset and the sequencer separately.
HW: Moog Sub 37 <> Moog Model D (original) <> Minitaur <> DSI OB-6 Desktop <> Roland Integra 7 <> Roland JD-XI <> Korg MS-2000 <> Korg Triton Le <> Audient ASP-880 <> RME Raydat
SW: Nuendo
Chimponaut
Postby ziggomatic » Mon Sep 12, 2016 10:16 pm
i know hehe but what i mean is to program my notes and the synth will play the notes randomly :)
ziggomatic
Postby _DemonDan_ » Mon Sep 19, 2016 2:55 pm
ziggomatic wrote:i know hehe but what i mean is to program my notes and the synth will play the notes randomly :)
Hi ziggomatic,
Part of the fun of "real" synthesis (at least for me) is finding ways to combine the tools that you do have to simulate a feature that you don't have.
I know this isn't the exact solution you were looking for, but here's a workaround that will give you similar results:
Plug a Footswitch pedal into the KB GATE INPUT jack on the side of the Sub 37.
Go to the GLOBAL mode and CURSOR DOWN to the CV MAPPING >>> sub menu.
Press the CURSOR button to enter CV MAPPING.
Set the GATE: parameter to SUST PED (at end of list).
Chose the correct value for GATE INVERT: so that your sustain pedal works as expected.
Set the front panel PATTERN knob to RND.
Light the ARPEGGIATOR ON button, but don't light the LATCH button (yet).
Use the KB OCTAVE buttons to find the lowest note you'd want in the sequence.
Now, with ARP ON, LATCH OFF, and the Sus pedal pressed, play the lowest note that would have been in your sequence.
While still holding the Sus pedal, individually press all of the notes from your sequence (using the KB OCTAVE buttons for way higher notes).
You'll now hear all of your notes randomized. When you have them all, light the LATCH button which will keep all of your notes going after you let off of the Sus pedal.
Again, not exactly what you wanted, but the end result will be very similar.
This is also a very cool trick for adding notes to an already LATCHed arpeggiation. While the arp is playing, press the Sus pedal and turn off LATCH. Now you can add more notes. When done, turn LATCH back on and let go of Sus pedal.
_DemonDan_
Postby _DemonDan_ » Mon Sep 19, 2016 4:01 pm
Having written all that...
I fully agree that a RANDOM mode for Sub 37 Sequences would be a very useful feature!
_DemonDan_
Return to Little Phatty & Slim Phatty Forum
Who is online
Users browsing this forum: Bing [Bot], CommonCrawl [Bot] and 1 guest
