Moog Polymode
Everything Phatty.
boneheaddap
Moog Polymode
Post by boneheaddap » Sun Apr 03, 2016 1:26 pm
I am not yet a Moog user but hope to be (in a big way) shortly.
I am very interested in the poly-chaining function I've read about. I have plans to create such a poly-chained Moog setup. I have been leaning towards a Little Phatty along with several Slim Phatty's (I know, both are discontinued).
Would there be any advantage to using the Sub 37, which I understand will also work in such a setup?
Thanks in advance...
David
boneheaddap
Re: Moog Polymode
Post by boneheaddap » Thu Apr 28, 2016 1:42 pm
Well I did it... bought my first Moog synth... a Slim Phatty!!!
Toom
Re: Moog Polymode
Post by Toom » Fri Apr 29, 2016 11:08 am
Moog should really pump this functionality (ie. Make slim Sub 37s) cause I would buy at least 2 to hook up to my Sub 37. What's the hold up?
till
Re: Moog Polymode
Post by till » Sat Apr 30, 2016 7:37 am
Polychaining to create a polyphonic synth from several monophonic synth is only getting the typical results, if all the synths sound more or less alike. But the SubPhatty and the Sub 37 sound different from the LittlePhatty and SlimPhatty.
Sequence:
Toom
Re: Moog Polymode
Post by Toom » Sat Apr 30, 2016 2:17 pm
I might have to buy another Sub 37 and chop it up to make a custom slim. Is that my only option Moog? ;)
till
Re: Moog Polymode
Post by till » Sun May 01, 2016 3:39 am
A four voiced SubExpander as a plain box to be controlled only via a Sub37 or a SubPhatty would be a nice thing. And due to the not needed Knobs not that expensive as buying just two Sub37.
Sequence:
