Defective Little Phatty II
Everything Phatty.
keyboardology
Post by keyboardology » Mon Feb 15, 2016 6:24 am
Good day,
I just bought a used Moog Little Phatty II, but there's something wrong with OSC2. It's always detuned to the extent of making every sound very wobbly (it's like all the sounds are heavily modulated). This affects most of the sounds except the ones with 'OSC Sync' on or those without OSC2 active.
Also I leave it to warm up for at least 45 minutes before I play.
The solution is to manually adjust the OSC2 frequency till it sounds right.
I did all the calibrations, and surprisingly the problem was solved. All the sounds were good with no wobble. But the very next day the problem was there again.
I was wondering if you know what the problem is and if there's a way to solve it. Your help is much appreciated.
K.
keyboardology
Re: Defective Little Phatty II
Post by keyboardology » Thu Feb 18, 2016 5:57 am
Guys any help with that issue?
paramnesia
Post by paramnesia » Thu Feb 18, 2016 10:14 am
keyboardology wrote:Guys any help with that issue?
have you considered contacting Moog service directly and asking them?
Andy Hughes, Service Manager
[email protected]
828-251-0090 xt 221
Nate Marino
[email protected]
xt. 204
Taylor Mott
[email protected]
xt. 217
have you registered your product in the system to create an RMA for service?
http://www.moogmusic.com/content/register-product
Sub37TE V1.2 / 4 X CP-251, 3 x MF-104M, MF-102, MF-107, MF-108M, 4 x Mother32 + 5 x 104HP Eurorack, Windows 7 - 64 Bit | Ableton Live 9.5 + MaxMSP https://www.modulargrid.net/e/racks/view/458782
Ledbetter
Post by Ledbetter » Thu Feb 18, 2016 3:25 pm
In the manual, you'll find a procedure for calibrating the oscillators and other components. Maybe worth a try.
stiiiiiiive
Post by stiiiiiiive » Fri Feb 19, 2016 11:15 am
.. or two. I've never had it but read that sometimes, running the procedure only once did not make it right. Suprising but well, worth a try.
