I ave a very strange issue here. I haven't used my Moog LP in about 3/4 months, it's been in a soft case stored away somewhere dry and warm. I've had it out today and it seems to only play every 16th note - that is, I can play the same note 16 times and it will only play the 16th, or I can play 16 different notes, and only the 16th will sound out.
I've just done a master reboot and there is no change in the problem. I can't do a firmware update right now as I don't have my midi interface to hand, however, it is running 3.125 (that's what it says when I boot it up).
Can anyone tel me what this issue might be, or how I can further trouble shoot?
Moog Little Phatty is only playing every 16th note
Re: Moog Little Phatty is only playing every 16th note
It's the POLY settings; I think they are found on the MIDI menu. Make sure POLY NUM (or it might be POLY MAX) is set to OFF. Otherwise the unit thinks it's one of "N" units in a poly-chain setup, where N = 16 in your case.
