Slim Phatty Knob Tracking Issues
Everything Phatty.
Sentrallya
Post by Sentrallya » Tue Mar 25, 2014 10:51 am
Hello everyone,
I apologize if this is something that has been discussed before, but I'm new to the forums and only have a moment to make a post, instead of digging through search.
I recently purchased the Slim Phatty and I'm loving it so far. However, I seem to be having an issue with the anlogue mode knob tracking on the front panel. Snap works perfectly fine, but Track and Pass-Thru are not accurate at all. The interface seems to have a problem with grabbing the initial patch setting when moving the knobs, especially on Pass-Thru. It won't grab the lit indicator half the time and then when it does, it seems to not want to move to where the main knob position indicator is pointing.
Any insight on this would be much appreciated. I'm running Mac OSX, midi over USB, and the Slim Phatty is on Rev. 3.12 680
ThenCameNow
Re: Slim Phatty Knob Tracking Issues
Post by ThenCameNow » Mon Jul 17, 2017 5:22 pm
You must turn off the local MIDI control.
MIDI SETUP
LOCAL CONTROL : OFF
No more MIDI loop and PASS-THRU works perfectly.
________________________________
RobertCharlesMann.com
ColeGaskins
Post by ColeGaskins » Mon Jul 17, 2017 9:19 pm
Should I turn off local control for phattys used in a poly chain?
