phatten your phatty
Everything Phatty.
CleverConQueso
phatten your phatty
Post by CleverConQueso » Sun Aug 11, 2013 11:18 pm
What are you folks using for delay or chorus to fatten up the sound of your phatty? I've got a multi tap setting on a kaoss pad that sounds pretty great but I would rather go with a more rugged solution like a foot pedal. I use my phatty for textures and the occasional lead in a rock band. I picked up a flashback X 4 and am tweaking it but I don't like that second bump you get when the delay kicks in. Particularly for pads and filter sweeps.
Thanks,
CCQ
Rabalder
Re: phatten your phatty
Post by Rabalder » Mon Aug 12, 2013 8:41 am
Have you tried the moogerfoogers? Pretty phat! The 108 even has stereo out. Twice as phat!!
ricknboogie
Post by ricknboogie » Mon Aug 12, 2013 10:22 am
Delay comes in many flavors, and two main types. Try an analog delay, like MXR Carbon Copy-though digital delays will generally offer more options.
robml
Post by robml » Mon Aug 12, 2013 5:52 pm
i use a modded deluxe memory man and a modded roger mayer voodoo vibe
stiiiiiiive
Post by stiiiiiiive » Mon Aug 12, 2013 6:25 pm
Hey Robml, how are your pedals modded?
mmarsh100
Post by mmarsh100 » Tue Aug 13, 2013 1:02 am
I sometimes put my Sub Phatty through a Synth Tech Frequency shifter, the e560. It also has a ring mod and phase shifter and a morphing carrier wave. Pretty nice piece of gear! I also put it through a DIY delay pedal that has tap tempo and modulation; it's a guitar pedal but it works very nicely with regular output of the Sub.
IgorCristo
Post by IgorCristo » Tue Aug 13, 2013 10:33 am
I'm using it with EHX Deluxe Memory Boy, Cathedral and Stereo Electric Mistress. :)
It sounds great with all of them!!
The reverb sounds fantastic with soft leads.
The flanger/chorus sounds great with many leads.
The delay sounds wonderful with everything!
Moog Minimoog Voyager Performer Edition and Little Phatty Stage II | Elektron Analog Four and Analog Rytm | Mutable Instruments Ambika | Korg Minilogue
Ledbetter
Post by Ledbetter » Tue Aug 13, 2013 2:37 pm
Deluxe Memory Boy here, too. I also like my TC Nova Delay. It's digital, but has a nice sound.
robml
Post by robml » Wed Aug 14, 2013 11:50 pm
stiiiiiiive wrote:Hey Robml, how are your pedals modded?
ive changed the caps that alter the delay time on the BBD. they reduce the amount of delay available, but it sounds warmer and when using heaps of feedback you get this amazing super warm space echo that feels a bit ethereal. i basically use it for that one sound ;)
the voodoovibe has a caps mod so you can change to the caps used in the original uni-vibe, the caps in the shinei RT18, or the original caps RM chose.
i dont actually own the originals, i just built clones.
cheers
stiiiiiiive
Post by stiiiiiiive » Thu Aug 15, 2013 7:17 am
cheers
Ok, thanks!
I'm just starting putting my hands in electronics so any little knowledge is good to take :)
Voltor07
Post by Voltor07 » Thu Aug 15, 2013 11:31 am
I use a digital EHX #1 Echo and Kevin Lightner's analog chorus effect, which is an RS-101 chorus board in a rack mount case. :) Also, I like the MF-103 phaser for whooshing effects.
Sub 37 #000068, Minitaur, CP-251, MF-102&103, EHX #1 Echo, EHX Space Drums/Crash Pads, QSC GX-3, Miracle Pianos, Walking Stick ribbon controller, Synthutron.com, Lowrey Teenie Genie.
Howard Scarr
Post by Howard Scarr » Sat Aug 17, 2013 7:46 am
TC Nova Repeater (http://www.tcelectronic.com/rpt-1-nova-repeater/) here. No extra chorus etc..
CleverConQueso
Post by CleverConQueso » Thu Aug 22, 2013 3:10 pm
Thanks, team. Sounds like delay is quite common and seasoned to taste. Got it. And thanks for chiming in.
deltaphoenix
Post by deltaphoenix » Thu Aug 22, 2013 10:46 pm
I was running my Slim Phatty through my Eventide PitchFactor and was getting nice chorus,vibrato, delay. Plus the pitch stuff. The Harpeggiator has a lot more arpeggiator setting than the onboard one. Plus Ice is cool for some ambient fun.
toschek
Post by toschek » Mon Sep 09, 2013 6:23 pm
I use Guitar Rig Pro or Reaktor, I know it's wrong, but it works so well...
