Amos: LP/Slim Firmware Suggestions
Everything Phatty.
David Smyth
Re: Amos: LP/Slim Firmware Suggestions
Post by David Smyth » Tue Jul 16, 2013 6:11 pm
jocks13 wrote:hello, here are my suggestions for sub phatty options: 1. I'd like the option to bypass mod.wheel so that PWM, pitch or filter can be modulated independent of the wheel position. 2. mod.wheel controls filter cutoff instead of filter mod.depth. 3. pitch bend on/off for osc 1 & 2. 4. hold note when MIDI CC sustain is sent to Sub phatty. 5. Option to switch modulation source to filter env. individually for filter, PWM & pitch.
/jocks13 in Sweden
This thread is not for the Sub Phatty - it is for the Little and Slim Phattys. Good ideas though!
David
NZ
Minimoog Voyager XL, Little Phatty Stage II + CV Output Mod, 2x Slim Phatty, Minitaur, MP-201, EP-2, 2x CP-251, MF-102, MF-104M, MF-107
tortur
Post by tortur » Sun Jul 21, 2013 1:48 pm
My suggestion is to get a firmware update that get oscillator two in a more stable tuning to oscillator one. Can this be done?
I love the sound of my slim phatty, but it is frustrating when I save a patch where the two oscillators are in tune, and when I later choose this patch oscillator two has drifted out of tune.
Sir Nose
Post by Sir Nose » Fri Aug 16, 2013 10:44 am
Any revised predictions on when the next stage/slim update will arrive?
Amos
Post by Amos » Fri Aug 16, 2013 11:55 am
this year some time... I might do a quick bugfix update soonish (like, next month or so) - at least to patch the vulnerability to MIDI Time Code messages.
Sir Nose
Post by Sir Nose » Sat Aug 17, 2013 12:00 am
Thank you.
JuanSOLO
Post by JuanSOLO » Sat Aug 24, 2013 1:42 pm
Amos wrote:...at least to patch the vulnerability to MIDI Time Code messages.
Not sure if this would relate to my current issues but hopfully so.
Since the latest Tempest OS update allowing for sequencing external gear, I have been going midi out from Tempest to midi in on my SlimPhatty.
LOTS OF FUN!
I have the arp and lfo clock set to external on the SP.
And I go out from the SP Midi Thru to sync other gear.
When playing the Tempest pads the SlimPhatty often hangs as if a note is being held. The Tempest pads then trigger the SP in reverse, and if pushing a pad is note off and release is note on.
Currently I just toggle the SP arp on and off right quick when this happens.
At first I thought this maybe a Tempest issue, but only the SP responds like this, so I am assuming this is some kind of midi issue with the SP.
So when you say the "vunerability to MIDI Time Code messages," could that be whats causing this?
Thanks AMOS!
Mike
Post by Mike » Fri Sep 13, 2013 7:48 pm
Sorry if I've missed anything but, with the discontinuation of the LP does that mean we'll never see another firmware update? There are still some things in this thread that really should be addressed.
Del-Uks
Post by Del-Uks » Sat Sep 14, 2013 7:02 am
Mike wrote:Sorry if I've missed anything but, with the discontinuation of the LP does that mean we'll never see another firmware update? There are still some things in this thread that really should be addressed.
Probably not...
My Moogs : Minimoog Model D #10790 • Slim Phatty #SP 00433 • Sub Phatty #SUB03422 • MP-201 Multi-Pedal #MP00344 • Moogerfooger MF-104M Analog Delay White Finish #2074 • Moogerfooger CP-251 Control Processor #3962
stiiiiiiive
Post by stiiiiiiive » Sat Sep 14, 2013 7:03 am
For now, the Little Phatty OS update is still to be delivered sometime this year. Plus the discontinuation news doesn't deal with Slim Phatty :)
Sir Nose
Post by Sir Nose » Sat Sep 21, 2013 8:52 am
My hope is that the slim is the saving grace for at least one more firmware update. If the newest firmware doesn't materialize or doesn't do it for me, I may get the usb debugger and roll back pre 3.0. Maybe just in my head, but menu nav doesn't seem to flow as smooth for me. I'd probably end up missing at least a feature or two and updating back to newest, but I might give it a try anyway.
Will a Sub-P rack kill the slim?
Del-Uks
Post by Del-Uks » Fri Sep 27, 2013 9:01 am
Hirlostek solve the missing noise source of the Little/Slim Phatty, but we desperately need an "Audio Input" level... please !
anxiogenn
Post by anxiogenn » Fri Sep 27, 2013 12:49 pm
A volume control for the Audio Input is exactly the function that lacks Little Phatty-
Amos please turn this option on the next update :D
Sir Nose
Post by Sir Nose » Sun Nov 03, 2013 7:06 am
New firmware for Christmas?
Vitja
Post by Vitja » Sun Nov 03, 2013 9:23 am
+1, for this gift!
Amos? Any info?
Gear:Slim Phatty, Arturia Minibrute, Casio MT-600, MF-101,MF-102,MF104Z,MP-201,CP-251,Ibanez John Scofield, PRS custom 24, circuit bent Kawai R-100,Circuit Bent Roland TR-505, Boss Dr55, Akai MPK 25, Ensoniq DP/4, RME Fireface 800, tons of guitar effects.
