Page 3 of 8
Re: Amos: LP/SP Firmware Suggestions
Posted: Wed May 15, 2013 6:14 pm
by David Smyth
In the Little Phatty's Midi Setup menu, regarding sending CC's: As well as "WHEELS", can we possibly have options for just the pitch wheel and just the mod wheel? If this is possible, it would add some more flexibility - especially controlling a poly chain.
David
NZ
Posted: Thu May 16, 2013 12:59 pm
by Vitja
Uh, it would be totally awesome to map a CV input to any parameter!!! Just like on Minitaur.
I really want to save LFO for filter mod, but I love PW mod and PW mod is something that needs just triangle LFO in mostly constant rate... I just want to say that would be great to control PW (uh sorry, Wave Shape) with CV in. And if you could control other parameters like resonance and LFO speed, that would be major upgrade in modular fashion!
Another thing I would love to do is:
Turning the resonance up and in the same time Volume up.
Turning O.L. up and volume down.
Controlling filter cutoff with mod wheel and adding modulation. - this is useful if you want to have filtered bass sound and when adding LFO to cutoff, you control the offset of LFO or you can say Cutoff frequency
this would be awesome if you could save (per preset) range of control and direction (+/-) of control.
ARP with/without retrigger option when using MIDI clock.
Posted: Thu May 16, 2013 1:01 pm
by Vitja
Sorry, with the second idea I meant pot mapping, so you control two parameters with one pot at the same time.
Posted: Thu May 16, 2013 1:04 pm
by mmarsh100
For Sub Phatty: a ring modulator.
Posted: Thu May 16, 2013 2:40 pm
by Elgo
Vitja wrote:Uh, it would be totally awesome to map a CV input to any parameter!!! Just like on Minitaur.
Seconded. Amos! This would be the ultimate upgrade for the Phatties.
Also, the ability to switch CV ins on the Slim to CV outs, but I don't know if that is feasible.
Posted: Thu May 16, 2013 3:43 pm
by kingfriday
+1 for this on the Sub Phatty, too. I rarely use the Volume CV in, so if it could be reassigned that would be pretty amazing.
Posted: Sat Jun 01, 2013 11:17 pm
by Sir Nose
Just thought of a huge one! Not sure if it is possible. Inspired by the sub phatty,
I'd love a front panel shift mode for the menu parameters for the stage and slim!
I hate relying so much on the push encoder, but the real advantage is after a bit of work all could be memorized. Button to select the menu parameter, knob in that section to adjust the value.
Menu parameters I'd like to see on a shift mode front panel
Filter pole
Legato
Glide
Clock source
ARP advanced preset menu parameters
I know there are some I am forgetting. I have been away from my LP for a couple of months, while in the middle of a renovation & move.
Also, the manual could use a rewrite with the major changes that have occurred over the years.
Posted: Sat Jun 01, 2013 11:22 pm
by Sir Nose
denoiser wrote:
BTW, if we could have a Panel mode like in the Sub, wouldn't it be better than the advanced preset menus?
Doh't. I'd didn't just think about it. I read it last month.
Posted: Mon Jun 03, 2013 9:12 am
by Vitja
I'm sure that I mentioned this somewhere but any way...
I wish I could turn ARP off and still holding the last note.
When you do that, ARP off command sends note off or something like that.
This is very frustrating for me.
I need to re press that last note if I want it to sound, and sometimes it is really hard to synchronize this two actions. I don't want to have a gap between this to actions.
What I like to do is one shot ARP in really fast time division up ward, but it would be much easier without note off when ARP is disengaged.
And another thing I also recommend is steady ARP with MIDI clock without offset, so you can hit note out of beat, but ARP stays in groove. Otherwise you really need to focus to play first note tight in sync and than you need to play legato if you want it to sound musical and in tempo.
Posted: Mon Jun 03, 2013 2:24 pm
by Amos
Vitja wrote:And another thing I also recommend is steady ARP with MIDI clock without offset, so you can hit note out of beat, but ARP stays in groove. Otherwise you really need to focus to play first note tight in sync and than you need to play legato if you want it to sound musical and in tempo.
this is definitely to be implemented! better late than never
Posted: Fri Jun 07, 2013 3:13 pm
by Vitja
Great! My band will sound much more tight then!
Any idea when this can happen?
Posted: Fri Jun 07, 2013 4:22 pm
by Amos
I would guess late summer... I am just finishing Sub Phatty stuff now, then I have Minitaur stuff next on my list.. then LP.
Posted: Sat Jun 08, 2013 6:55 am
by Vitja
Great! Just take your time, and don't forget your vocation if there is such a thing
Posted: Sat Jun 08, 2013 7:35 am
by stiiiiiiive
Vitja wrote:don't forget your vocation if there is such a thing
You mean his
vacation, right? Because Amos is definitely not forgetting his vocation here
Posted: Sat Jun 08, 2013 8:13 am
by Vitja
Ups, my bad English.
Holidays!
For sure!
