LP Stage Midi output velocity
Everything Phatty.
Pewt
Post by Pewt » Tue Jan 24, 2012 3:04 am
Whem using my LP stage as a midi controller I always have to bang on the keys quite hard to higher velocity values. is there a way to adjust the sensitivity of the midi velocity?
stiiiiiiive
Re: LP Stage Midi output velocity
Post by stiiiiiiive » Tue Jan 24, 2012 5:24 am
This should most likely be set on the slave instrument, not on the Moog itself.
Mr Shave
Post by Mr Shave » Tue Jan 24, 2012 5:48 pm
Really? I have the same issues when im just recording midi with the intention of sending it back to the LP... I usually end up increasing the velocity manually on my midi tracks...
soundxplorer
Post by soundxplorer » Tue Jan 24, 2012 6:09 pm
I don't think there are adjustable curve settings in the LP.
Gear: Moog LP, Gibson LP, lots of FX
Pewt
Post by Pewt » Tue Jan 24, 2012 6:23 pm
thats pretty disappointing if it is true. the velocity curve on the phatty is so low I have to put a midi velocity effect on every track I use it on in ableton.
stiiiiiiive
Post by stiiiiiiive » Tue Jan 24, 2012 6:31 pm
I suggest you guys request this as a next OS feature :)
