No midi and error message: LPUSB INVALID SEND LPUSB SYX
Posted: Tue Jan 10, 2012 8:40 am
by HECTRUSO
Hello every body,
my LP shows this message LPUSB INVALID SEND LPUSB SYX wen I turn it on.
Since it appears on the screen it receives no midi so I'm trying to play it with a sequencer
with no success.
Anyone has had the same problem???
what to do?
Re: No midi and error message: LPUSB INVALID SEND LPUSB SYX
Posted: Wed Jul 11, 2012 9:47 am
by StevieGkeys
Did you ever find the solution to this problem? I am having the same problem.
Steve
Posted: Mon Jul 29, 2013 6:42 pm
by felix4414
Hey!
Did either of you find out the solution to the problem?, I'm going through the same thing, I'm super desperate to find out ow to overcome it!
Posted: Mon Jul 29, 2013 11:38 pm
by Amos
this is the kind of problem that moog tech support is there to handle, contact them if the following files don't work.
but first, here's the USB firmware sysex file for Little Phatty:
http://seamslikereality.com/moog/LP_USB_v33.zip
and here's the USB firmware sysex for Slim Phatty:
http://seamslikereality.com/moog/SLIM_USB_v34.zip
try sending that file via USB to the Phatty... it might fix the problem.
seems to work better from a PC than from a Mac, in my experience so far.
Posted: Wed Jul 31, 2013 7:18 am
by felix4414
Hi Amos!
Thanks for the reply, I have tried uploading the files with no luck. Trying both a pc and mac, it seems the phatty and computer do not talk. I have emailed moog but have not recieved a reply yet.
Do you think it is possible to us a silicon laboratories USB debug adaptor? What exactly does it do, I have seen a video where the guy greatfuly quotes you as the person who helped him.
Thanks in advance
A
Posted: Thu Aug 01, 2013 12:44 pm
by Amos
does the Phatty show up as MIDI device on the computer at all?
If not, you may actually need a new USB board, which is relatively inexpensive as replacement Phatty parts go (sub-$50) or we'll replace it under warranty if within the warranty period.
The USB Debug adapter is about $35 last I checked; might want to compare cost of the debug adapter to cost of a replacement USB board from Moog, and decide which is the better value for you. We can help you either way.
Posted: Wed Aug 21, 2013 5:37 pm
by felix4414
Hey Amos!
Managed to get the USB debugger through the post today, where can i get the relevant HEX files from?
Kind regards
Allan
Posted: Fri Jan 16, 2015 1:12 am
by Eihcra
Hi all! Did anyone figure out a fix? I just got the LPUSB message. Do I just need a new Field upgrade part for stage to stage ii? Or firmware upgrade? Both?
The LP works perfectly except for the message on start up. I still wanna stick to the LP. Not too sold on the new moogs... yet anyway
Started with a Theremin. Now I'm here.
Posted: Sun Oct 21, 2018 11:06 am
by mattialucchini
Amos wrote:this is the kind of problem that moog tech support is there to handle, contact them if the following files don't work.
Hi Amos,
i just had the same problem with my Phatty. But i just can't find the LP_USB file anywhere
You know where i could find it ?
Many thanks for your answer
Best,
Mattia
