Going Polyphonic With The Moog Slim Phatty And Little Phatty
Everything Phatty.
JWaltman
Re: Going Polyphonic With The Moog Slim Phatty And Little Ph
Post by JWaltman » Tue Jan 11, 2011 7:15 pm
thanks for posting this! Awesome :)
Marzzz
Post by Marzzz » Mon Jan 24, 2011 1:18 am
At the Moog both at NAMM last week they had a LP with an additional 3 Slims chained together as a 4-voice, and it sounded fantastic. It makes me wonder if it is possible to build a 1u rack with all the Slim Phatty guts but no knobs, displays, etc.; just a bare box that would be controlled by a LP. I think that would be the closest to getting a polysynth Moog for a "reasonable" price.
dan thacker
Post by dan thacker » Mon Nov 28, 2011 2:59 pm
that's duo phonic, and what do all those hand signals mean?
gruvsyco
Post by gruvsyco » Fri Dec 02, 2011 2:51 pm
dan thacker wrote:that's duo phonic, and what do all those hand signals mean?
wow... did you resurrect a nearly year old thread to be a jerk?
Technically duophonic is polyphonic as in, mono = 1 and poly = more than 1. To me, duophonic in its more traditional synth usage is like the Arp Odyssey where it's technically a 2 osc mono synth that allows you to separately trigger the 2nd osc.
dan thacker
Post by dan thacker » Fri Dec 16, 2011 12:02 pm
"Technically",poly means many,duo means two,end of story.
Sir Nose
Post by Sir Nose » Fri Dec 16, 2011 1:24 pm
dan thacker wrote:"Technically",poly means many,duo means two,end of story.
No, not end of story. Do some research. A word is defined by its usage, not the other way around. Duophony is the simplest form of polyphony. Poly as a prefix has more than one meaning. Confusing, I know. One of its meanings is many. Another happens to be more than one. In the case of the word polyphony, the prefix poly is being used to mean more than one not many.
dan thacker
Post by dan thacker » Fri Dec 30, 2011 12:45 pm
O.k., so poly can mean more than one.You buy a poly synth from ebay.Only two keys can be played simultaneously.Are you going to conclude that it's alright,because according to your definition of poly, that's correct?
muksys
Post by muksys » Fri Dec 30, 2011 1:22 pm
monophonic: Only 1 note can be played at a time.
duophonic: A synth that has 2 (or more) oscillators. If 2 or more keys are pressed, 1 osc is assigned to each press. If only 1 key is pressed, all osc's are assigned to one note.
polyphonic: A synth that can have 2 or more voices. Each voice is assigned to a key press. If a synth has a polyphony of 2 with 2 oscillators per voice, it basically has 2 monophonic synths with 2 oscillators each, giving a total of 4 oscillators. When 2 keys are pressed, the synth will assign 1 key press per voice in succession. In a LP & SP polyphony setup, the LP acts as the master synth (voice 1). All commands stack to SP (voice 2). When playing a polyphonic note, the LP will play the first note and then the LP will send the second note down the chain to the SP. When the total number of voices are reached, it will drop the first note and start the chain over again.
So, having more than 1 phatty in a chain is a Polyphonic synth.
End of story :wink: :wink: :wink: :wink:
_DemonDan_
Post by _DemonDan_ » Fri Dec 30, 2011 2:18 pm
dan thacker wrote:"Technically", poly means many, duo means two, end of story.
So a man with two wives is "technically" a duogamist?
acatcalledanarchy
Post by acatcalledanarchy » Fri Dec 30, 2011 4:01 pm
:D
A Cat Called Anarchy
Voyager Select Series Whitewash Electric Blue, Little Phatty Stage II, Minitaur
_DemonDan_
Post by _DemonDan_ » Fri Dec 30, 2011 4:47 pm
Then a man with three wives is a Newt!
