Skateboarding - All you need to know
Everything Phatty.
stiiiiiiive
Re: Can the Sub Phatty tempo sync filter and amp envelope repeats?
Post by stiiiiiiive » Tue May 11, 2021 7:43 pm
Hi and welcome to the forum!
The Sub Phaty will most probably not be updated now tht the Subsequent 25 is out.
The loop envelope functionality is toggled via a cheat combination: are ou sure the sync is not available the same way?
You may want to consult the cheat sheet for Sub Phatty or Subsequent 25.
EDIT: I've just checked, apparently not. Anyone, prove me wrong!
