I Just Bought An Etherwave
- Jrayk Roze
I got it online, of course. So now, I have to wait in Moog purgatory >:|
Do they have serial numbers on the back of them?
Voyager Old School #0005, Etherwave #18321, Stereo Memory Man w/ Hazarai, CP-251, and a Nord Lead 2X
- Portamental
- Klopfgeist
- Jrayk Roze
No, I got a standard Ash Etherwave (to match my old school) used for $340.Portamental wrote:Congrats! One with CV's? A kit?
Assembled units have a sticker with the serial number, on the bottom of the case.
What kind of mic stands do you need for these theremins?
I was told when I bought my theremin that a tripod mic stand is reccomended. I have never tried it on a round base stand, but I think a tripod would certianly be more stable.
Now instead of a Mic Stand, you can put it on a stool or some other table that is at the right height as long as there are no nails or misc particleboard junk that might mess up the magnetic field.
When you get your theremin, Im sure you won't be able to keep your hands on the thing. (yes that was really lame)
- Jrayk Roze
I ordered a tripod base mic stand with it, but because of supply irregularities, the theremin will be coming a few days before the stand.
I haven't been this excited since my last episode of Moog purgatory.
- Portamental
A round base Mic stand might make it straighter. If you try to put it with your synths a tripod stand might be crooked (if that matters to you). A round base mic stand might be better on a hardfloor whereas a tripod might be better on a thick carpet. The carpet here is over an inch thick and Id hate to bump into my theremin on a round based stand on this carpet.
This photo isn't where we are staying now, the carpet is different. I posted to show how crooked it can be. For me who likes to look at my gear for inspiration sometimes, it being crooked can be off putting lololl.
I have my EW+ mounted on a tripod boom stand, tilted out over the top of my Voyager. It is very sturdy, though I needed to tie the back end of the boom to the vertical pole of the stand to keep the boom from slowly pitching forward. Before I tied it, it looked like it was solid. However, when I got up the next morning, the boom had dropped down, and the EW was gently resting on the front of the Voyager's keyboard! No damage was done, and a lesson was learned.EricK wrote:
The boom is almost fully extended, and is tilted at about 10-15 degrees from vertical, out over the Voyager. If you do something like this, please be sure to orient the stand's legs exactly like Eric has his in the photo above, with one leg facing forward (in line with the direction of where the boom is tilting...) otherwise the stand will fall over.
If the EW is mounted on a straight, vertical stand, then a heavy round base is probably going to be adequate, provided you're careful to prevent it getting tipped over, especially if there are kids around. Otherwise, I would go with a tripod stand as it is less prone to tipping, though you would still want to be careful, especially with kids around.
Lets evaluate the parts of MY particular tripod stand to show the problems facing it.
You have the tripod legs, that join at the base of the shaft that houses the extender. In that shaft is the pole upon which the theremin screws.
The shaft itself will slide up and down (making the whole stand really small for storage), allowing the shaft to even rest on the floor, or to be held suspended in the base where the legs meet. This will give the whole stand either an inch or so of extra height or added stabillity. This also makes getting the whole thing to stand STRAIGHT difficult. So even though the stand is set up in a way where there is a forward leg that might prevent a forward lean of the theremin, youll notice in the picture that my theremin has a sideways lean, due in part to the stand being on carpet AND in part because of the stand itself.
A Good heavyweight stand should be siffucient either of a tripod style of a really heavy bottomed round base.
I hope this was clear, if not ill take some photos clearly showing the fault with my particular stand.
- Jrayk Roze
