Theremini factory reset ?
Share your theremin experience: tips, tricks, techniques, favorite theremin moments.
Don23805
Post by Don23805 » Sat Mar 04, 2023 4:48 pm
How do you do a factory reset on a Theremini? Don't get any hits on a search of the manual, but forum posts mention doing it.
And, BTW, how do you open the case? Removing the 4 bottom screws doesn't seem to help. The Curious need to know!
Don23805
Re: Theremini factory reset ?
Post by Don23805 » Tue Mar 07, 2023 11:22 am
Here's the answer from Moog Tech Support and verified by me: power off; hold Root & Setup; power on. The display even says Factory Reset and tells you to recalibrate.
Haven't done it yet, but they also said that to take the case apart, you remove the 4 screws on the bottom, then remove the feet and there are additional screws under them.
