Moog Music Forum
Share Ideas and Pass the word
Advanced Settings Load from Presets Effects Mix - Um...?
Share your theremin experience: tips, tricks, techniques, favorite theremin moments.
Postby uncoolcentral » Tue Aug 08, 2017 6:34 pm
In the Theremin advanced settings, under "load from presets" I'm able to select yes/no for "effects mix" What does that do? I was thinking it would NOT load effects on presets if set to NO, but it always loads effects presets regardless of what I set that setting to.
On the other hand, (sort of a pun, right?) when I set scale/root to NO, the presets do NOT overwrite whatever root/scale I'm using. Similarly, if I set "correction amount" to NO, scrolling through the presets does NOT change the correction amount I've set.
...So, what gives? I'd like to be able to quickly switch to presets w/out having their effects settings change what I've got loaded, but only when I have "Effect mix" set to NO. (I.e. I'd like to have the ability to also set it to YES and get all the pre-programmed fx for each preset, too, sometimes.)
Thoughts? Ideas?
I know I could customize the presets to NOT have effects, but that's not the point; I like the idea of being able to globally turn them on and off. Possible?
-DD
uncoolcentral
Return to Theremin Forum
Who is online
