Moog Music Forum
Share Ideas and Pass the word
Electric shock?
Share your theremin experience: tips, tricks, techniques, favorite theremin moments.
Electric shock?
Postby kaiweb » Tue Jun 13, 2017 1:42 am
Hi, I'm going to make a modification to the main circuit board. Just wondering if I need to be concerned about electric shock from any capacitors or anything.
kaiweb
Re: Electric shock?
Postby d'ni » Tue Jun 13, 2017 10:18 pm
hi kaiweb,
what theremin are you modifing? and what are you modifing? i soldered myself some stuff on the etherwave plus, without any problems. like suggested in the hotrod-manual. and adding the espe-module was a no brainer. just unplug the unit and turning it then on should discharge the big capacitors. and discharge yourself to prevent esd on the delicate parts like chips and such.
d'ni
Re: Electric shock?
Postby kaiweb » Wed Jun 21, 2017 6:02 am
Thanks so much. Indeed I was planning on installing the espe01 module on my Etherwave Plus, and I have heard that sometimes the large capacitors can retain a charge for a while. I appreciate the tips, and I was able to successfully install the module.
kaiweb
Return to Theremin Forum
Who is online
Users browsing this forum: CommonCrawl [Bot], Google [Bot] and 0 guests
